MJKTuck(at)cs.com Guest
Posted: Fri Jun 11, 2010 10:08 am Post subject: Band Clamps |
Hi Folks,
I am forever having trouble keeping the exhaust heat shield located
using the 6 inch worm drive band clamps. I tighten hem up as hard as I
can but they expand with the heat and vibrate off.
I'm looking for a source of the type of clamp found on the Rotax oil
tank holding the two halves together (except with a plain band not a
v-section) that you do up then close tighter with a mechanical lever.
Any ideas?
Martin Tuck
Europa N152MT
Wichita, Kansas
rparigoris
Posted: Fri Jun 11, 2010 10:38 am Post subject: Band Clamps |
Hi MartinI am unfamiliar clamps that hold on 912/s heat shields (have a 914). You may want to have a look at www.mcmaster.com for some ideas.Ron Parigoris [quote][b]
keithhickling(at)clear.ne Guest
Posted: Sat Jun 12, 2010 4:42 pm Post subject: Band Clamps |
| Quote: | Hi Martin,
Europa recently issued a SB recommending lockwiring of the clamps for this
reason. I did mine and found that they had become very loose after 40 hours.
Now still fine after 120 hours. The lockwiring is a bit fiddley but not too
difficult.
Keith Hickling.
XS 613, 912uls, Airmaster.
| Quote: | "I am forever having trouble keeping the exhaust heat shield located using
the 6 inch worm drive band clamps. I tighten hem up as hard as I can but
they expand with the heat and vibrate off."
gavanne(at)iconz.co.nz Guest
Posted: Sat Jun 12, 2010 4:50 pm Post subject: Band Clamps |
Take them off and get rid of the heat shield, not really needed and excess
weight
Gavin Lee
ZK-EPA
