Posted: Thu Jun 10, 2010 2:47 pm Post subject: Misc topics... First flight, Insurance, Rudder lock |
The little tabs are welded to the back side of the existing tube. I put the tow bar in place on the nose wheel and marked how much was left protruding so I could tell where to attach the tabs.
I used a little longer screw and a large area washer to capture the bungee. The bungee end is just bent in a tight circle for the bolt to go through. Then I shortened the bungee a couple inches so it holds the stick securely.
Dave Saylor
AirCrafters
140 Aviation Way
Watsonville, CA 95076
831-722-9141 Shop
831-750-0284 Cell
On Thu, Jun 10, 2010 at 2:47 PM, n277dl <dljinia(at)yahoo.com (dljinia(at)yahoo.com)> wrote:
[quote] --> RV10-List message posted by: "n277dl" <dljinia(at)yahoo.com (dljinia(at)yahoo.com)>
Thanks for the input.
Dave, is the only modification to the tow bar welding a tip that fits between the brake pedal and the rudder bar?
Doug
Doug
"Fools" are always more creative than process people and will always find ways to ruin a perfectly good set of processes.
http://forums.matronics.com/viewtopic.php?p=300884#300884
le, List Admin.
