Posted: Sun Jun 06, 2010 11:41 am Post subject: Rotax 914 Intercooler |
Talking about cooling...
I have the intercooler for the Rotax 914, per factory setup.
My airbox temperature sensor shows no difference if I seal off the
intercooler!
While solving my cooling problems, I learned a few things:
1) Naca ducts provide no ram air, but merely "allow air to get in".
2) The cowling is somewhat "pressurised" by the openings in front.
How is the intercooler supposed to work, "connected" on the inlet to a
naca duct which provides no pressure, and the outlet venting into a high
pressure area?
I know quite some folks are flying around with an intercooler. Has
anyone indeed measured the drop in temperature? Has anyone ever found
bugs or other contaminations in the radiator? If so, were they on the
bottom or on the top of the radiator?
Frans
kevann(at)gotsky.com Guest
Posted: Sun Jun 06, 2010 1:47 pm Post subject: Rotax 914 Intercooler |
Hi Franz,
Very interesting. Have you tried this sealing off the intercooler up at high
altitude? I think the cooler should be doing more "work" the higher you are
cruising?
I don't have an airbox temp sensor, but I wish I could repeat your test
below. I too have the factory setup installed. You pose some interesting
questions on the installation. I wonder if air is flowing though the cooler
from the naca inlet as designed?
Kevin
intercooler!
rparigoris
Posted: Sun Jun 06, 2010 2:12 pm Post subject: Re: Rotax 914 Intercooler |
Hi Frans.
I did speak to John Hurst and he said he measured airbox temp and especial at altitude it dropped with intercooler. He mentioned it dosen't work so well you really need to worry about carb ice, but would allow one to fly to 18K without intervention of TCU. I am only repeating what he said, I have yet to measure. For what it's worth, my 1983 Volvo GLT-50 (245) turbo station wagon, with 2.3 liter 4 cylinder, pretty much same as 914 Garette air cooled turbo as 914, and ~ 185hp said intercooler lowered air temperature going into manifold from 145F above ambient to only 45F above ambient. I think boosts were similar to 914?? Size of radiator was about size of coolant radiator.
Intercooler installed as per factory instructions from John do in fact lead to further constipation of cowl air compared to not having it installed. A mono with gear down and factory located stainless firewall has far worst exit air ability than a Tri with firewall moved way back. None the less still not stellar on the ground and in climb.
Ron Parigoris
Posted: Mon Jun 07, 2010 1:13 am Post subject: Rotax 914 Intercooler |
On 06/07/2010 12:12 AM, rparigoris wrote:
| Quote: | Hi Frans. I did speak to John Hurst and he said he measured airbox
I don't know how hey measured it. It is hard to make a valid comparison,
unless you have fitted a valve and can close off the supply of cooling
air flowing through the rad.
After I couldn't measure any temperature difference, I fitted such a
valve... And found out that the intercooler has no measurable effect.
Tested with 115% power, and at 10.000 feet...
My findings are supported by the following theories:
1) Naca ducts are bad in providing ram air. They merely "allow air to
get in".
2) The intercooler is in a 90 degree angle towards the supposed stream
of air getting in via the naca duct. Now, turn your water radiator 90
degrees into the airstream. Let the air first slam the wall, and then
find its way upwards to the radiator. I guess you wouldn't be surprised
to find out that the cooling rad almost stops working.
3) Is the cowling a high or a low pressure area? Where does the
intercooler exit its air into?
4) Radiators that work correctly collect contamination (dust, bugs) over
a while. I can find plenty of these in my water radiator, but have found
none in the intercooler. Has anyone find such contaminations in his
intercooler? I asked before but so far everyone keeps silent about this
(which may be an indication that some people are just starting to
reluctantly wondering whether their setup is effective at all)...
5) Intercoolers don't need "just some air" to work properly, they need
loads of air, due to reason that they need to cool something with a very
small temperature difference.
Frans.
