		chris Sinfield
  Joined: 28 Nov 2006 Posts: 270 Location: Sydney Australia
				 Posted: Sat Jun 05, 2010 3:29 am    Post subject: AN-3 nyloc nut torque |
				people
 what torque are you doing these little nuts up to with the .125 th spar plate?
 on the AC43-13B it talks about 25"lb. Zenith  construction standards the same. Problem is they are still loose when the torque wrench clicks, not bottomed out, loose.
 some one suggested adding the friction TQ of the nut. to the published TQ
 The good book AC 43 said max 40"lb. So what have others been using as the TQ value?? At 40 its firm and you can still move the whole bolt and nut a little with a spanner if u rotate the head.
 the A4's are OK just the little A3's that worry me, logic says you should not be able to move the bolt when done up to the correct torque.
 Am I over worried?
 Chris.
  |  | - The Matronics Zenith601-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Terry Phillips
  Joined: 11 Jan 2006 Posts: 346 Location: Corvallis, MT
				 Posted: Sat Jun 05, 2010 4:01 am    Post subject: AN-3 nyloc nut torque |
				Hi Chris
 I used the info from Zenair's construction standard CS#407, which says:
  	  | Quote: | 	 		  Drag torque. Run the nut down to near contact with the washer and check
 the friction drag torque required to turn the nut. Add the drag torque to
 the desired torque. This is referred to as the final torque which should
 register on the indicator or setting on the torque wrench.
 And, as you note, CS#407 specifies 20-25 in-lbs for AN3's with AN365 nuts.
 The problem is, I do not see any way to measure the drag torque with a
 "click" type torque wrench. So I chose a "beam" type wrench, the Park TW-1,
 IIRC. It is actually sold as a bike tool, ~$40 USD.
 With my bolts, nuts, and wrench, I measure a drag torque of ~4 in-lb, so I
 torqued my AN3 to between 25 and 30 in-lb. That nut and bolt seem to be
 plenty tight to me. Perhaps your click wrench is not accurate in the low
 in-lb ranges.
 Terry
 At 04:29 AM 6/5/2010 -0700, you wrote:
  	  | Quote: | 	 		  people
 Am I over worried?
 Chris.
 Terry Phillips
 ttp44~at~rkymtn.net
 Corvallis MT
 ZU-601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail & flaps are done;
 Upgrading wings & ailerons per the AMD Safety Directive
 http://www.mykitlog.com/N47TP/
  _________________ Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
Zenith 601XL/Jab 3300 slow build kit - Tail feathers done; working on the wings. |
		floyd wilkes
  Joined: 11 Jun 2007 Posts: 39 Location: spring branch, tx
				 Posted: Sat Jun 05, 2010 4:38 am    Post subject: AN-3 nyloc nut torque |
				Chris,
 Make sure you have the correct length bolt.  If the bolt is too long, the
 nut will hit the shoulder and not allow it to become tight.  You are correct
 you will not be able to move the bolt if all is right.
 Floyd Wilkes
 601XL
  _________________ Floyd Wilkes |
