Issues with getting Lightspeed RPM readout posted to Dynon
ranchlaseigneurie(at)hotm
PostPosted: Wed May 19, 2010 5:15 pm    Post subject: Issues with getting Lightspeed RPM readout posted to Dynon Reply with quote
for your info it has 2 pulse per rev, and works OK
gilles
bsl aviation
[quote] Subject: RE: Issues with getting Lightspeed RPM readout posted to Dynon EFIS
Date: Wed, 19 May 2010 13:09:23 -0400
--> AeroElectric-List message posted by: <longg(at)pjm.com>
Thanks All,
Good point Werner. I will check the signal output voltage and post at
Dynon.
Glenn E. Long
longg(at)pjm.com
PostPosted: Thu May 20, 2010 4:53 am    Post subject: Issues with getting Lightspeed RPM readout posted to Dynon Reply with quote
Gilles,
Yes, as below that is my current setting. There is some other voodoo in
progress. I will try every other reasonable option before I throw them
over the cliff. The last call I will make is to Klaus.
Eric M. Jones
PostPosted: Thu May 20, 2010 9:38 am    Post subject: Re: Issues with getting Lightspeed RPM readout posted to D Reply with quote
Apropos of the topic, for some years I have been offering a tachometer pulse-divider for those who need one, or just to play with.
Tach Adapter.pdf
Divide by two tacho module.
 Filename:  Tach Adapter.pdf
 Filesize:  102.52 KB
 Downloaded:  606 Time(s)
Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net
