Flap control detent
rickofudall
PostPosted: Tue May 18, 2010 6:47 am    Post subject: Flap control detent Reply with quote
Now that I've seriously started using the flaps on my Mk III I've just about worn the detents on the track away and there are divots in the plate on the flap handle, too. They won't stay in the up position on the ground but air pressure holds them up in flight and last night the handle popped off the full flap detent twice. Mine is an early aircraft and the track and the plate on the flap handle are just .063" steel with no hardening or wear prevention.  Any changes to new models? Fixes? I'm thinking of two ways to go, adapt an emergency brake handle out of a car and mount it down between the seats so the release button can be operated by a pilot of normal dexterity, or go with a 12V linear actuator. Either would give more adjustment than just the half and full settings (which I have no trouble with and am unsure of the value of more than that).
Rick Girard
ces308
PostPosted: Tue May 18, 2010 8:34 am    Post subject: Re: Flap control detent Reply with quote
Rick...
I attached a spring to hold it in the detent...it works well...I will take a picture and post to see....
chris ambrose
M3X/Jab 128.4 hrs
N327CS
clrprop
PostPosted: Tue May 18, 2010 9:41 am    Post subject: Re: Flap control detent Reply with quote
The plate on my handle is in good shape but the detents were worn. I cut out a new one and riveted it on top of the original.
Keath T
MkIII C
ces308
PostPosted: Tue May 18, 2010 10:20 am    Post subject: Re: Flap control detent Reply with quote
the spring works great...holds it tight to the detent and doesn't rattle around wearing it out....for what it's worth...
As Roseanne Roseanna Danna says,"It just goes to show you,it's always something !"
chris ambrose
m3x/jab
n327cs
 Filesize:  636.65 KB
 Viewed:  6614 Time(s)
by0ung(at)brigham.net
PostPosted: Tue May 18, 2010 12:54 pm    Post subject: Flap control detent Reply with quote
Rick Girard
Years ago I visited my brother and we visited some of his flying friends, they were using power window motors for flap actuators.
When I put my mkiii together, I cut the bottom of the square detents with an angle cut up and toward the left. and cut the flap handle to match, this way the more pressure on the flaps pulls the flap handle into the notch tighter.
Boyd Young
MKIII
Ps
The weather guessers are forecasting the Weather for MV as ok, not stellar, but ok ,   northern utah a bit iffy to get out. My flying choices are rain or wind or I could drive down. I will be checking the weather close.
Do not archive.
Richard Pike
PostPosted: Tue May 18, 2010 5:12 pm    Post subject: Re: Flap control detent Reply with quote
As long as you are modifying the handle, here is an alternative, gives you as many options for flap positions as you want to drill holes, and that roll pin will last longer than either one of us...
http://www.bcchapel.org/pages/0003/pg3.htm
Richard Pike
MKIII N420P (420ldPoops)
