ianxbrown
Posted: Mon May 17, 2010 8:22 am Post subject: Flap Fuse |
How about disconnecting the pushrods and checking for resistance to movement by moving each flap manually? Excessive current draw suggests that the motor is struggling. You could divide the movement in two - the motor to the push rods and the push rods to the flaps. If you feel no resistance to movement on the flap side then maybe there's some interference or tightness on the motor side. Could anything be misaligned, interfering or overtightened in motor to pushrod chain?
Ian Brown
"I have an RV-7a with 700 hours on her and a month ago the flap fuse ( 7.5amps )
blew on two consecutive landings. The fuse has
never blown before in those 700 hours. I know I was well below the white arc,
10 to 15 knots below, on both of the landings.
After I changed the fuse on those two, it went almost a month without ever happening
again, then the fuse below twice more over the
course of a few landings.
It always blows on the downward movement, but the point at which it's blown varies
anywhere between just barely having moved and
being as much as 20 degrees when it happens."
denis.walsh(at)comcast.ne Guest
Posted: Mon May 17, 2010 9:55 am Post subject: Flap Fuse |
The flap motor has a clutch and slips when the resistance gets too high, so it is unlikely that this is the problem, given the intermediate position of the flap when it occurs.
I would look for an area of high resistance in the circuit. Check the switch for all connections. Check all crimps, and check the connections at the fuse. Check the connections at the actuator, and at the power bus. Lastly don't forget the ground side of the circuit.
If all those check out, I would do a current measurement, and make sure the fuse is big enough. Remember the fuse is sized according to the wire size and length.
Good luck and let us know how it comes out.
Denis
On May 16, 2010, at 5:20 , Ian wrote:
[quote] How about disconnecting the pushrods and checking for resistance to movement by moving each flap manually? Excessive current draw suggests that the motor is struggling. You could divide the movement in two - the motor to the push rods and the push rods to the flaps. If you feel no resistance to movement on the flap side then maybe there's some interference or tightness on the motor side. Could anything be misaligned, interfering or overtightened in motor to pushrod chain?
Ian Brown
