dutrac
Posted: Tue May 11, 2010 11:39 am Post subject: Flight regulations at Airventure |
Hey all,
I'm sure I could research this out, but thought I would ask the group first and see what I can glean from your experience. I have given some thought to trailering into Oshkosh with my Kolb MKII with the hope that I could perhaps fly around the patch like they do there.
Just wondering how much red tape you have to go through to actually do that. Any input is appreciated.
Duane
Posted: Tue May 11, 2010 12:11 pm Post subject: Flight regulations at Airventure |
Duane
Duane/Gang:
Not too much red tape.
When you get to the Oshkosh UL area, go to the red barn, UL Hq.
Register your aircraft.
Sit in on the next fixed wing briefing at UL flight ops.
You are good to go.
Based on slow times in the UL area at Oshkosh the last couple years that I
did not attend, I feel they will welcome your presence.
john hauck
_________________ John Hauck
Titus, Alabama |
radiobluebook(at)gmail.co Guest
Posted: Tue May 11, 2010 2:48 pm Post subject: Flight regulations at Airventure |
Do you have to show your license or any of that? I should have it, but it will be close.
On Tue, May 11, 2010 at 2:55 PM, John Hauck <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)> wrote:
| Quote: | --> Kolb-List message posted by: "John Hauck" <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)>
Duane
Duane/Gang:
You are good to go.
john hauck
-List Email Forum -
http://forums.matronics.com
le, List Admin.
Sincerely,
Duane
www.amateurradiobluebook.com
Posted: Tue May 11, 2010 3:06 pm Post subject: Flight regulations at Airventure |
Titus, Alabama |
capedavis(at)yahoo.com Guest
Posted: Tue May 11, 2010 3:57 pm Post subject: Flight regulations at Airventure |
John , Will you be there this year ? bECKY AND i WERE VERY DISAPOINTED LAST YEAR VERY FEW ULTRALIGHTS AND VERY FEW LIGHT SORT AIRCRAFT FLYING THAT IS . cHRIS
Chris Davis
KXP 503 492 hrs
Glider Pilot
Disabled from crash building Firefly
Sent: Tue, May 11, 2010 3:55:20 PM
Subject: Re: Flight regulations at Airventure
Duane
Duane/Gang:
You are good to go.
john hauck
bsp; -Matt Dralle, ===========
Posted: Tue May 11, 2010 4:24 pm Post subject: Flight regulations at Airventure |
Chris Davis
Chris D/Gang:
No plans until after I finish up my flight out West.
Have moved my departure up to Sunday. That will give me 4.5 days instead of my normal 2.5 days to arrive by noon Thursday. The 2.5 day flight required two 8 hour and one 4 hour day, without any time for weather. Extending my time by two days will allow me to fly shorter days, take it easy if I get tired, or if I have to wait out winds and weather.
Anxious to get to Monument Valley and see my old friends and make some new ones.
Wish everyone could make this flyin. It is the best.
john hauck
Titus, Alabama |
Ralph B
Joined: 14 Apr 2007 Posts: 367 Location: Mound Minnesota
Posted: Tue May 11, 2010 4:36 pm Post subject: Re: Flight regulations at Airventure |
As far as I know, EAA doesn't check for licenses. A couple of years ago, there were two exact Firestars sitting side by side. One had numbers and the other a fat ultralight w/o numbers. The EAA didn't do anything that I was aware of. The UL pilot flew it from the St Louis area without a GPS using pilotage and sectionals. They do look over your plane and if they see something wrong with it (like a missing bolt), they will ground it. They will also ground the pilot if you cross the runway w/o permission (must go the long way around along the sides). Attend the morning briefing and you should be good to go. They want you to call the red barn before flying in. Should you have a rough landing or damage anything upon landing, the FAA will be called on the spot. Be aware and keep your eyes open and stay at 300' in and out. The EAA has a good video on their website showing the pattern/route in and out of the convention for LSA's/UL's.
Ralph
_________________ Ralph B
Kolb Kolbra 912uls
N20386
550 hours |
Posted: Tue May 11, 2010 5:06 pm Post subject: Flight regulations at Airventure |
Check it out, Oskosh 2010 UL/Lightplane NOTAM:
http://www.airventure.org/flying/ul.html
john hauck
mkIII - 3,008.5 hours
912ULS - 440.0 hours
US - 385.0 hours
FS - 1,135.0 hours
Total: 4,825.5
The above is time in my Kolbs. Took 26 years to get that time in my Kolbs.
That averages to 185.6 hours per year overall. However, there were
approximately 7 years of down time due to building, rebuilding, and
overhauling, all three aircraft. For the years my airplanes were actually
flying, I averaged 254.0 hours per year. Since my last flight to Alaska,
2004, I have flown very little, other than my annual flight West which takes
about 75.0 flight hours. Does not include hours in other Kolbs, GA, and
military aircraft.
Titus, Alabama |
neilsenrm(at)gmail.com Guest
Posted: Wed May 12, 2010 4:37 am Post subject: Flight regulations at Airventure |
It is a good time flying in and camping under the wing of my Kolb at Airventure. I hope to fly in and camp again this year. In recent years there have been so few planes flying it was down right sad.
One special note about flying in. They require that you call the Red Barn to get permission to fly in. Don't assume that any information given during the call will be accurate or that they will tell anyone that you are inbound. If there aren't any planes flying in the pattern do a fly by on the south west side of the strip to verify landing direction. Maybe they have fixed this procedure but?
Rick Neilsen
Redrive VW Powered MKIIIC
On Tue, May 11, 2010 at 9:06 PM, John Hauck <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)> wrote:
[quote]--> Kolb-List message posted by: "John Hauck" <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)>
john hauck
US - 385.0 hours
FS - 1,135.0 hours
Total: 4,825.5
military aircraft.
List Un/Subscription,
www.matronics.com/Navigator?Kolb-List" target="_blank">http://www.matronics.com/Navigator?Kolb-List
ronics.com/" target="_blank">http://forums.matronics.com
Matt Dralle, List Admin.
by0ung(at)brigham.net Guest
Posted: Wed May 12, 2010 9:31 am Post subject: Flight regulations at Airventure |
Fyi
The weather in Utah has been quite iffy this spring. More days of wind and rain than I would like, the jet stream has been overhead and when it has been clear the wind seems to blow, the flying has still been lumpy. Had my first smooth flight this spring last Saturday. Usually around this time of year we get the change over from this crud to good flying weather, Last night the weather guessers said that southern Ut will be clear and dry may 15 – 17th. The same time frame in northern Ut is cloudy. I will try and let you know what the weather guessers have to say as it gets closer to the departure dates.
Looking forward to seeing as many as can make it this year.
Boyd Young
MKIII
Utah
| Quote: | >>>>>>>>>>>>>>>>>>>>>>>>>.
john hauck
