mike(at)learningplanet.co Guest
Posted: Wed May 05, 2010 3:36 pm Post subject: Door/Baggage Locks |
Hello all,
I'm wondering if anyone has solved this problem: I am trying to find three door locks, one for the baggage door and one each for the main doors. Spruce sells a set of two, but I'm not sure if these can be re-keyed. I'd like for all three locks to use the same key if possible.
By the way, my ignition will not have a key as it uses the Vertical Power system.
Any help would be appreciated.
Mike Schipper
#40576 - finishing - www.rvten.com
bcondrey
Posted: Wed May 05, 2010 3:59 pm Post subject: Door/Baggage Locks |
IFLYRV10.com
rleffler
Posted: Wed May 05, 2010 4:30 pm Post subject: Door/Baggage Locks |
You can get them from iflyrv10.com.
If you are more energetic, you may be able to pick them up at home depot or
lowes. Your local locksmith should also be able to assist. Most sell
hardware.
bob
_________________ Bob Leffler
N410BL - Phase I
Jim Berry
Posted: Wed May 05, 2010 6:54 pm Post subject: Re: Door/Baggage Locks |
If you are using a keyed ignition switch, you can special order from ACS a switch and three door/baggage locks all keyed alike. A little more expensive to special order, but I really like having only one key for everything.
Jim Berry
40482
Ron.McGann(at)ausawd.com Guest
Posted: Wed May 05, 2010 9:47 pm Post subject: Door/Baggage Locks |
Just a bit of a heads up for those not based in the US of A, I ordered the 2 lock system from Spruce, but only received one key. When I tried to have a duplicate cut here in Oz, I could not find a locksmith that had key blanks that matched the US style. So I still only have one key (that I am VERY careful with) until I find a local distributor for cam locks of the appropriate size.
Cheers
Ron
VH-XRM flying in Oz
LarryRosen
Posted: Thu May 06, 2010 4:07 am Post subject: Door/Baggage Locks |
Aircraft Spruce does sell blank keys (uncut).
I special ordered a third door lock from spruce to have it match the
other locks. Call them, they make the process easy.
Larry Rosen
Cheers
Ron
VH-XRM flying in Oz
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
martinaerodrome(at)gmail. Guest
Posted: Thu May 06, 2010 4:46 am Post subject: Door/Baggage Locks |
Mike,
I own a hardware store with a resident locksmith and a laarge inventory of "Cam Locks" also known as vending machine locks. I would suggest however that you go to a local locksmith to buy them because the lock cams may need adjustment etc to suit your particular installation, also, he will be able to set up all three locks with the same key eliminating the nusiance of careing 3 different keys. If you need more info, call me (at) 920 619 6968.
Good Luck
Dick Martin
RV8 N233M
the fast one
On Wed, May 5, 2010 at 6:35 PM, Michael Schipper <mike(at)learningplanet.com (mike(at)learningplanet.com)> wrote:
[quote]--> RV10-List message posted by: Michael Schipper <mike(at)learningplanet.com (mike(at)learningplanet.com)>
Hello all,
Mike Schipper
www.matronics.com/Navigator?RV10-List" target="_blank">http://www.matronics.com/Navigator?RV10-List
ronics.com/" target="_blank">http://forums.matronics.com
Matt Dralle, List Admin.
Posted: Thu May 06, 2010 6:00 am Post subject: Door/Baggage Locks |
Thanks to Dick and everyone else who responded.
So "Cam Lock" is the official name for these things, huh? Now that I know what they are called I did a search on McMaster-Carr and found a nice selection. They can be ordered with the same key number.
http://www.mcmaster.com/#cam-locks/
Mike Schipper
On May 6, 2010, at 7:45 AM, Richard Martin wrote:
| Quote: | Mike,
Good Luck
Dick Martin
RV8 N233M
the fast one
partner14
Posted: Thu May 06, 2010 6:54 am Post subject: Door/Baggage Locks |
Ron, a friend of mine is a 182 owner, and took my key and went over to the local FBO and bought several blanks directly from them ... apparently, they're the same as the Cessna keys.
Don
--- On Wed, 5/5/10, McGann, Ron <Ron.McGann(at)ausawd.com> wrote:
Subject: RE: Re: Door/Baggage Locks
To: "rv10-list(at)matronics.com" <rv10-list(at)matronics.com>
Date: Wednesday, May 5, 2010, 10:43 PM
--> RV10-List message posted by: "McGann, Ron" <Ron.McGann(at)ausawd.com (Ron.McGann(at)ausawd.com)>
Cheers
Ron
VH-XRM flying in Oz
40636 |
msausen
Joined: 25 Oct 2007 Posts: 559 Location: Appleton, WI USA
Posted: Thu May 06, 2010 7:20 am Post subject: Door/Baggage Locks |
I got mine from Lowes or Home depot, don't remember which. Just match the numbers on the package for keyed alike. I think I spent less than $20 for all three.
Michael
Jim Berry
Posted: Thu May 06, 2010 8:57 am Post subject: Re: Door/Baggage Locks |
Also be aware that some cam locks are longer than those sold by Van's or ACS, and will not fit within the depth of the baggage door.
Jim Berry
40482
coop85(at)verizon.net Guest
Posted: Thu May 06, 2010 4:01 pm Post subject: Door/Baggage Locks |
Ron,
Same situation here in the US regarding the key blanks. However you can
order a blank from Spruce. I suspect any key maker could cut the blank, the
trick is just getting the blank.
Marcus
Posted: Thu May 06, 2010 5:48 pm Post subject: Door/Baggage Locks |
Thanks Marcus,
I did not realise that you had the same problem over there. I responded to a few guys off list that I was about to head to the States on business and would get some keys cut whilst there. But given this new intel, I will order some blanks from Spruce.
Cheers
Ron
VH-XRM - flying in Oz
