rparigoris
Posted: Wed May 05, 2010 9:46 am Post subject: D-sub questions |
Hi Group
I have a few questions about D-sub connectors:
**How many amps are each pin good for using the nice machined pins?
**How many amps are each pin good for using solder on pins?
**I want to run my Ray Allen pitch and roll servo wiring through D-sub connector. Would it be advisable, especially on the pitch to parallel two pins?
**I need to run 4 shielded wires out on my instrument module (2ea. mic and speaker). I would like to use a D-sub connector on the bottom port side of my instrument module to allow easier instrument module removal and install. Thus there will be a few inches of unshielded wires at the connector:
$$Should I use D-sub shielded shells? This D-sub connector is about 5" away from my Dynon D-10A
**I have a single point ground on firewall with field of tabs. I think I remember seeing for avionics and instruments (can't find it) a D-sub connector with perhaps 3 or 4 wires going to field of tabs, and all the pins connected to one side to those 3 or 4 wires to make a field of pins to be used for single point ground. Is this acceptable for grounding on the same connector:
$$mic and speaker shield?
$$Radio and transponder grounds?
$$Instrument grounds?
Thx.
Ron Parigoris
Posted: Wed May 05, 2010 7:41 pm Post subject: D-sub questions |
At 12:46 PM 5/5/2010, you wrote:
Quote: |
<rparigor(at)suffolk.lib.ny.us>
Hi Group
The continuous rating for individual pins is 7A
Quote: | **How many amps are each pin good for using solder on pins?
Same . . .
You can run a LOT of current through a D-sub connector. See:
http://www.aeroelectric.com/Pictures/Connectors/D-Subminature/Paralleled_D-Sub_Pins.jpg
I used this technique to run 20+ amps through D-subs on
this vehicle's . . .
http://aeroelectric.com/Pictures/Misc/GQM_1st_Ops_Flight.jpg
DC power distribution assembly . . .
http://aeroelectric.com/Pictures/Misc/GQM_Power_Dist.jpg
which featured solid state switching. In this application,
we de-rated pins to 4A each and paralleled 5 pins for
the 20A conductors. The de-rating was in recognition of
our 70C max operating environment.
Quote: | **I want to run my Ray Allen pitch and roll servo wiring through
parallel two pins?
Can't think of a good reason why.
Quote: | **I need to run 4 shielded wires out on my instrument module (2ea.
Quote: | $$Should I use D-sub shielded shells? This D-sub connector is about
No, take shields through the connectors on their
own pins. Actually, these signals can be carried
very nicely on twisted pairs and/or trios with
no shielding but if you choose to shield, treat
the shields as separate conductors.
Quote: | **I have a single point ground on firewall with field of tabs. I
FOLLOW THE WIRING DIAGRAM FOR THE PRODUCTS YOU
ARE INSTALLING.
Shields on wires that run between black boxes
GENERALLY terminate on either some specific pin
in a connector or the connector's back-shell.
They NEVER get long pigtails off to some remote
ground location.
The grounding configurations shown in Appendix Z
are for accessory power grounds, not system signal
or shield grounds.
