Matt Dralle Site Admin
Joined: 08 Nov 2005 Posts: 28109 Location: Toledo Washington (KTDO) USA
Posted: Thu May 06, 2010 8:31 am Post subject: Vertical Power VP-200 |
At 05:38 AM 5/6/2010 Thursday, you wrote:
And looks like VP-200 should be on the list below as the main bus. I am planning on one when I get to the panel. I'd be curious as to your opinions both on the install and first flight of the VP-200.
-Sean #40303
On 5/5/10 8:27 PM, Matt Dralle wrote:
>Electrical System: Vertical Power VP-200
I would highly recommend the VP-200. Installation is very nice as the big red box has all of the wires for each circuit. You simply program each wire for the type of device and expected load. The device is named accordingly, for example "Strobes", and shows up on the main LCD display.
Operationally, each mode of flight, for example "Taxi, Run Up, Takeoff, Cruse, Landing, etc.) is programmed into the VP-200. You specify which devices you want on and off during each mode of flight. The VP-200 can automatically detect each mode of flight and will automatically switch on/off the devices for the given mode of flight as you have preprogrammed them. You can at anytime manually override the automatic setting of a given circuit if necessary.
Basically, you turn the VP-200 on, and fly the plane. All of your electrical needs are handled automatically.
Factory support has be excellent.
I wouldn't build another airplane without a Vertical Power electrical system.
RV-8 #82880 N998RV
http://www.mattsrv8.com - Matt's RV-8 Construction Log
Status: Phase 1 Test Flying
163.6 KB |
2661 Time(s) |
137.2 KB |
2661 Time(s) |
_________________ Matt Dralle
Posted: Thu May 06, 2010 9:52 am Post subject: Vertical Power VP-200 |
I agree completely!
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
On May 6, 2010, at 12:29 PM, Matt Dralle wrote:
> -Sean #40303
RV-8 #82880 N998RV
<2010.01.07 - RV-8 - Front Baggage Area Complete (1).jpg><2009.08.22 - RV-8 - Primary Alternator Installation & Wiring (12).jpg>
sean(at)stephensville.com Guest
Posted: Thu May 06, 2010 9:57 am Post subject: Vertical Power VP-200 |
Sorry, missed it in the list originally. Very nice. I am looking
forward to getting there.
-Sean #40303
> -Sean #40303
RV-8 #82880 N998RV
