Fox5flyer Guest
Posted: Sun May 02, 2010 11:47 am Post subject: Emailing: kitfox muffler |
Mike, do you have any photos you can send of your slip joints? I have about 450 hours so far with no problems, but I suspect that one day I will.
Deke
michael.logan1(at)verizon Guest
Posted: Sun May 02, 2010 2:11 pm Post subject: Emailing: kitfox muffler |
Deke,
This is what it looks like before you install it; http://www.aircraftspruce.com/catalog/eppages/hydroformslipjoinst.php
I ordered the SPG-4 gearbox and have the engine off ready to install new pulleys on the other end of the engine. I had to use a different location for my ignition pickups.
Mike
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of fox5flyer
Sent: Sunday, May 02, 2010 3:42 PM
Subject: Re: Fw: Emailing: kitfox muffler
Deke
----- Original Message -----
From: Michael Logan (michael.logan1(at)verizon.net)
To: kitfox-list(at)matronics.com (kitfox-list(at)matronics.com)
Sent: Sunday, May 02, 2010 7:11 AM
Subject: RE: Fw: Emailing: kitfox muffler 014 (2), kitfox muffler 015 (2), kitfox muffler 016 (2), kitfox muffler 017 (2), kitfox muffler 018 (2)
Larry,
Nice looking muffler system. Did you allow for expansion differences between the engine and the muffler? I had a similar system (NSI) on my Kitfox and it developed cracks at the pipe/muffler joint. I ended up putting a slip joint right at the muffler and no problems after that. It is a much quieter system with the muffler.
Mike Logan
Kitfox Series 5 RAM EA-81
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of larry huntley
Sent: Saturday, May 01, 2010 10:40 AM
Subject: Fw: Emailing: kitfox muffler 014 (2), kitfox muffler 015 (2), kitfox muffler 016 (2), kitfox muffler 017 (2), kitfox muffler 018 (2)
Subject: Emailing: kitfox muffler 014 (2), kitfox muffler 015 (2), kitfox muffler 016 (2), kitfox muffler 017 (2), kitfox muffler 018 (2)
I don't know if these will come through,but I told you I would try to let you know about the results of my muffler for the Kitfox 4-1200 EA-81. I had 2 straight stacks on it for 550 hrs. It was awful after the 1st 2 hrs. ;o)
I didn't know much about mufflers ,but with a lot of help from the group and particularily from Al Wick,I have an exhaust system that seems to work very well. If you check Al's posts and ideas you will find info for a system that works better than advertized. I made my first flight with it today. I flew over a friends house. He said a little later a C-172 flew over much higher and my plane was much quieter. My wife and I have never been able to converse in the Fox,but today I talked with her on a cell phone from the air. The difference is spectacular. The only change I made from Al's plans was to make it 10" long instead of 6". This was only because I had the material and the space. Tomorrow we fly to Breakfast about 20 mi away. We will get Mary's input. Larry Huntley,Dundee,NY
The message is ready to be sent with the following file or link attachments:
kitfox muffler 018 (2) | Quote: | | href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.comhref="http://www.matronics.com/contribution">http://www.matronics.com/c | | [/b]http://forums.matronics.com[/url] - List Contribution Web generous nbsp; -Matt Dralle, List href="http://www.matronics.com/contribution">http://www.matronics.com/c=[/b] [b]
