Andair Fuel Valve
flysrv10(at)gmail.com
PostPosted: Fri Apr 23, 2010 3:38 am    Post subject: Andair Fuel Valve Reply with quote
Hello All,
Has anyone installed an Andair fuel valve on the 10 without extensions or modifications? If so, what is the model number? Thanks.
Rob
Do not archive.
jeff(at)westcottpress.com
PostPosted: Fri Apr 23, 2010 8:52 am    Post subject: Andair Fuel Valve Reply with quote
Hi Rob,
I installed Andair Valve 20X7T as it came from Vans at the top of the
tunnel cover. It took some careful tube bending to route the scat
under the valve.
Jeff Carpenter
40304
On Apr 23, 2010, at 4:27 AM, Rob Kermanj wrote:
Hello All,
Thanks.
Rob
Do not archive.
 Filesize:  100.96 KB
 Viewed:  2825 Time(s)
rleffler
PostPosted: Fri Apr 23, 2010 12:46 pm    Post subject: Andair Fuel Valve Reply with quote
I used the FS20x7m. I ordered the 12" extension, then cut it down to about
three inches. This is what you'll need if you use the current location for
the fuel valve per plans. I don't know when Van's moved the location of
the valve. I got my fuse kit about 14 months ago. The new elbow fittings
look like you can get even more flexibility.
Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler
PostPosted: Fri Apr 23, 2010 2:06 pm    Post subject: Andair Fuel Valve Reply with quote
Thanks for the info.
Rob
