flysrv10(at)gmail.com Guest
Posted: Fri Apr 23, 2010 3:38 am Post subject: Andair Fuel Valve |
Hello All,
Has anyone installed an Andair fuel valve on the 10 without extensions or modifications? If so, what is the model number? Thanks.
Rob
Do not archive.
jeff(at)westcottpress.com Guest
Posted: Fri Apr 23, 2010 8:52 am Post subject: Andair Fuel Valve |
Hi Rob,
I installed Andair Valve 20X7T as it came from Vans at the top of the
tunnel cover. It took some careful tube bending to route the scat
under the valve.
Jeff Carpenter
40304
On Apr 23, 2010, at 4:27 AM, Rob Kermanj wrote:
Hello All,
Thanks.
Rob
Do not archive.
100.96 KB |
2877 Time(s) |
rleffler
Posted: Fri Apr 23, 2010 12:46 pm Post subject: Andair Fuel Valve |
I used the FS20x7m. I ordered the 12" extension, then cut it down to about
three inches. This is what you'll need if you use the current location for
the fuel valve per plans. I don't know when Van's moved the location of
the valve. I got my fuse kit about 14 months ago. The new elbow fittings
look like you can get even more flexibility.
_________________ Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler |
Posted: Fri Apr 23, 2010 2:06 pm Post subject: Andair Fuel Valve |
Thanks for the info.
Rob
