clemwehner
Posted: Fri Apr 16, 2010 11:49 am Post subject: 912 installation manuals |
We are installing a never-run 912 UL that was made in 1997.
At the time (1997), Rotax published an installation manual that had values for torques, probe placement etc.
Last year ( 2009), Rotax published a new installation manual covering all 912s, including the UL, that showed different values than in the older install manual.
Specifically:
1. The old manual said exhaust flange nut torque 90-170 inch pounds, the new manual says 177 inch pounds? Which one to use?
2. The old manual said EGT probe placement is 70 mm from the exhaust flange, the new manual says 100mm. Which one to use?
Should we go with the latest values, or the values in the manual published at the time the engine was made?
Hope someone can help, thanks,
Clem & Chris
Oklahoma
KFIV-912
_________________ Clem
Oklahoma
Kitfox IV-912, under construction since 1991 |
Roger Lee
Posted: Sat Apr 17, 2010 5:14 pm Post subject: Re: 912 installation manuals |
Values changed for most of us on certain parts. You should be using the new values because the old may have had an issue Rotax was tweaking.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
