Lynn Matteson
Posted: Wed Apr 14, 2010 9:48 am Post subject: No Title |
I think what you may be encountering is that when you have the other
valve fully depressed, the valve spring forces the camshaft away from
its otherwise "neutral" position, causing the adjacent valve
clearance to increase. I never thought about this before you
mentioned it, but to me it is a possibility. This points out that the
cam is floating in about .002" of oil, eh?
Lynn Matteson
Jabiru 2200, #2062, 910.3 hrs (since 3-27-2006)
Countdown to 1000 hrs~89.7 to go(101 days to go)
Sensenich 62"x46" Wood (summer)
Rotec TBI-40 injection
Status: flying (and learning)
On Apr 13, 2010, at 5:06 PM, Robert Rivard wrote:
| Quote: | Any advice on setting the valve clearance on a 2200 solid lifter
engine. I followed the manual by rotating the prop 360 degrees from
when the valve was fully depressed and set at .010.I did all the
valves following this proceedure. Then I rechecked by checking the
clearance by rotating engine till one valve was depressed then
checked the other. The valve which was set at .010 now has a
clearance of .012 in this position. This was true of all the valves
when I checked using the second method..Which is correct?
BOB
www.matronics.com/contribution _-
| | - The Matronics JabiruEngine-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?JabiruEngine-List |
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
