Weight & Balance Spreadsheet
Site Admin
PostPosted: Fri Apr 09, 2010 4:21 pm    Post subject: Weight & Balance Spreadsheet Reply with quote
Dear Listers,
I finally weighted the 'ol RV-8 last night. Gulp. As expected, pretty heavy. I did forget to fill it up with oil before I weighed, however, so I'll have to redo my weighing after I do that.
In the meantime, I created a spreadsheet to calculate the Weight & Balance. The sheet calculates a number of common scenarios and allows for the user-entering of various parameters such as pilot weight and plane weights as well as the various arms. Its setup for an RV-8, but could very easily be modified for other models of RVs. After I finished it, I thought other builders might like to use it as well. It comes with no guarantees whatsoever.
You can click on the link below to download either the PDF or the Excel spreadsheet:
PDF Format:
http://www.matronics.com/MattsRV8/WeightAndBalance/RV-8WeightAndBalance-Version1.0-MattDralle.pdf
Excel Format:
http://www.matronics.com/MattsRV8/WeightAndBalance/RV-8WeightAndBalance-Version1.0-MattDralle.xls
RV-8 #82880 N998RV
rv8builder
PostPosted: Sat Apr 10, 2010 2:41 am    Post subject: Weight & Balance Spreadsheet Reply with quote
Why re-weight it? If you know the weight of the oil and the arm of
the oil sump, just do the math. IMHO.
Dale
On Fri, Apr 9, 2010 at 8:20 PM, Matt Dralle <dralle(at)matronics.com> wrote:
Dear Listers,
PDF Format:
Excel Format:
RV-8 #82880 N998RV
Dale
