AMSOIL
capedavis(at)yahoo.com
PostPosted: Fri Apr 09, 2010 6:28 am    Post subject: AMSOIL Reply with quote
KOLBERS Has anyone had any experince with AMSOIL? The owner of "Ultralight center" claims to have never had a rebuilt engine cease in 1q3 years!He builds his engines with ceramic coated pistons also . anybody using one of his engines ?
Chris Davis
KXP 503 492 hrs
Glider Pilot
Disabled from crash building Firefly
 Filesize:  20.86 KB
 Viewed:  2963 Time(s)
williamtsullivan(at)att.n
PostPosted: Fri Apr 09, 2010 8:06 am    Post subject: AMSOIL Reply with quote
Chris- I used it in an old Chevelle with a 327 high compression engine, to make it start easier in the winter. Worked great, oil consumption went down, hellishly expensive at the time. Nothing bad to say about the brand, except the price.
      Bill Sullivan
      Windsor Locks, Ct.
      FS 447
Richard Pike
PostPosted: Fri Apr 09, 2010 6:08 pm    Post subject: Re: AMSOIL Reply with quote
If you use it at 100:1 in a Rotax 277, the engine will actually rattle, and when you hear it in flight, it is not a smiley face moment. However, it did make it back to the field, and after replacing the 100:1 premix with 50:1, the noise went away. Apparently it gives a really good oil film, but at 100:1, not as much as Rotax intended.
Must not have hurt anything, replaced the Amsoil that same year with the much cheaper Injex, and last I heard, the engine had about 750 hours on it, the only internals I ever replaced in 13 years was one piston and 2 sets of rings.
Richard Pike
MKIII N420P (420ldPoops)
