ARS Contest
cpayne(at)joimail.com
PostPosted: Mon Apr 05, 2010 3:39 am    Post subject: ARS Contest Reply with quote
If any of you folks attending All Red Star at Porterville feels the need for speed...well I have a contest proposal I'd like to see tried out so it can be replicated at other events. Basically it's a timed from a pass over the runway, out about 5 to 6 NM, around a "pylon" which is an easy to see road intersection where a "judge" can check for pylon cuts and then back to the airport to stop the clock.
Sounds simple enough but I have to tell you that some practice is required to get a good line around the pylon without eating up too much time and bleeding off a lot of energy. Holding a precise heading and altitude helps shave off seconds as well.
This isn't just for CJ's; Yaks, RV's and spammers could try this too. Each run will be over in 5 minutes so several airplanes could run the course during the late afternoon or early morning when other events aren't running and the bumps are smoother.
Let me know, off 'list, I have a proposed course, over flat land, free from towers, and a scenario on how this could work. If a fun-type contest is the result, we could replicate at other events and maybe even award "Speedy" patches to class winners??
Craig Payne
dougsappllc(at)gmail.com
PostPosted: Mon Apr 05, 2010 7:24 am    Post subject: ARS Contest Reply with quote
Hey Craig, fishing for info on how fast the competition may be??  Don't think it works that way, sorry.[img]cid:338(at)goomoji.gmail[/img]
Doug
On Mon, Apr 5, 2010 at 4:38 AM, Cpayne <cpayne(at)joimail.com (cpayne(at)joimail.com)> wrote:
--> Yak-List message posted by: Cpayne <cpayne(at)joimail.com (cpayne(at)joimail.com)>
Craig Payne
rget="_blank">http://www.matronics.com/Navigator?Yak-List
http://forums.matronics.com
le, List Admin.
 Filesize:  541 Bytes
 Viewed:  2540 Time(s)
mark.bitterlich(at)navy.m
PostPosted: Mon Apr 05, 2010 7:49 am    Post subject: ARS Contest Reply with quote
What ever happened about the other contest proposal?
Mark
smime.p7s
 Filename:  smime.p7s
 Filesize:  5.09 KB
 Downloaded:  351 Time(s)
PostPosted: Tue Apr 06, 2010 2:52 am    Post subject: ARS Contest Reply with quote
Not fishing, just being realistic as there will never be a single meet given the wide distribution of our locations. I expect to run the same course as everyone else. It's not just side x side speed. Skill in sharp pilotage and pylon turning can shave seconds off a short 12NM course anyway.
This could be a fun thing that fills in some open holes in the schedule and any pilot can do it. Formation rating not required.
Craig Payne
