Terry Phillips
Joined: 11 Jan 2006 Posts: 346 Location: Corvallis, MT
Posted: Thu Apr 01, 2010 4:38 pm Post subject: Length of the bottom rear skin on the XL series |
Hi Carlos
I'm a long way from building this part, but from my dwgs, the bottom skin on the XL is single piece, 3085-mm long. The access door is shown in 6B3 as taking up the length between the 5th and 6th (from the rear) angle reinforcements. The reinforcements around the door are Z's while the rest of the reinforcements are L's. It is 545-mm wide by 580-mm long. 'Hope that helps.
Terry
At 06:18 PM 4/1/2010 -0400, you wrote:
| Quote: | Hello,
I want to incorporate the door in the rear fuselage, as shown in drawing 6-ADO-1 on my 601-HD.
( http://www.zenithair.com/zodiac/xl/xl-up-manuals.html )
The HD bottom skin is composed of 2 parts: one 340mm long, the other 2224 mm long. They are joined with a 20 mm overlap, resulting on a piece 2545 mm long (there must have been a change in temperature between the measurements...).
So I can properly located the door, could someone tell me the length of the corresponding part(s) on the XL?
Drawing 6-ADO-1 does not provide all the measurements, and I don't want to make assumptions...
Carlos
CH601-HD, plans
Montreal, Canada |
Terry Phillips
ttp44~at~rkymtn.net
Corvallis MT
ZU-601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail & flaps are done;
Upgrading my wings & flaps per the AMD Safety Directive
http://www.mykitlog.com/N47TP/ [quote][b]
_________________ Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
Zenith 601XL/Jab 3300 slow build kit - Tail feathers done; working on the wings. |
