Nanchang CJ6
Posted: Tue Mar 30, 2010 7:27 pm Post subject: Sell Nanchang CJ6 aircraft parts |
P/N Des.
1 SBL-40 inverter
2 SBL-53 inverter
3 QDF-1 Compressed air solenoid valve
4 1J-S34-1
5 GZ-14 Tachometer transmitter
6 H2-6121-106 fuel filter cup
8 H2-6904-00 fixing pin
9 H2-6901-320 rubber bushes
10 GWR-1 Resistor temperature sensor
11 H2-3700-00-1 Flap hinge
12 H2-3204-20 Trim hinge
14 H2-9840-100A Air charging hose
15 Airfield power cable
18 H2-5522-00 Emergency air valve
19 H2-4230-40 Front gear uplock
20 H2-4130-50 Main gear uplock
21 H2-9830-400 Air charging tool with manometer
22 GR-8 Thermocouple
1 Ignition coil DH-2
2 Indicator light(White) ZSD-1
3 Indicator light(Red) ZSD-1
4 Indicator light(Green) ZSD-1
5 Indicator light(Yellow) ZSD-1
6 Indicator light(Purple) ZSD-1
7 Tail Light(White) WD-1
8 wing tip nav. Light(Red) HD-3
9 wing tip nav. Light(Green) HD-3
10 Push button AN-1A
11 Push button AN-3A
12 Push button AN-2
13 Gear switch H2-4260-01/03
14 uplock A/C H2-4230-50
16 PRV assembly H2-5502-00
17 valve H2-5522-00
18 gear guard plate( right side) H2-4311-00-1
19 magnetic compass LC-2
20 front wheel hub LW-11
21 brake cable screw H2-5113-05
22 pulley H2-5230-00
23 pulley H2-5407-30
24 pulley H2-5403-20/5
25 emergency air bottle H2-5506-10
26 plug H2-5506-13
27 Nipple H2-5505-31
28 washer H2-5505-32/1
29 reducing valve QS-1
31 deposit filter QL-17
32 air charging connector JT-7A
P/N
1 Prop Cap and nut
2 crush washers for oil sump
4 Air flap valve
5 Prop governor control bracket
6 QS-1 air valve
7 QS-2 air valve
8 spark plugs
9 brake pads
10 brake air bladders
11 Small Light bulbs for exterior
12 Small Light bulbs for interior
13 Air filters for air pump (box)
14 Gill shutter rods
15 Gill shutters
16 Gill shutter complete assembly ring
17 Fuel cover Zeus
18 Copilot lunch box Zeus
19 Wing tip fairings
20 Oil cooler wing faring
21 Air pressure gauge cockpit
P/N Eng Des.
1 12-5522-00 Double action valve
2 H2-5522-00 Emergency valve
3 H2-5503-00 Check Valve
4 H2-5523-00 Hose
5 H2-5524-00 Hose
6 H2-5526-00 Hose
7 H2-5532-00/3 Hose
8 H2-5532-00/5 Hose
9 H2-1030-100 Anti-Dust Cover
10 H2-0109-110 Seat pad
11 H2-7510-90 Seat pad
12 HB2-30B Pin
13 BM5GB62 Nut
14 GB1018-20 Washer
15 H2-9850-900 Oil Table
16 H2-9850-100 Screw Jack
17 H2-9820-200 Screw Jack
18 H2-9810-200 Screw Jack
19 H2-9820-300 Control Lock
20 H2-9820-400 Control Lock
21 H2-9260-10 Cover
P/N Qty
HB1-101-10x20x2.8 2
HB1-404G-M10 5
HB1-104-10x20x2.8 3
H2-3000-02 1
BM8GB54-45 1
HB1-125-5x29.5x2 2
HB1-404G-M4 4
HB1-125-5x41.5x2 2
HB1-125-5x41.5x2 2
HB1-502LB-4x3.5 2
H2-4250-00 1
H2-4150-00 2
H2-4220-00 1
_________________ Sarah's E-mail:lcdzkj@live.cn |
craig ekberg
Posted: Wed Mar 31, 2010 5:42 am Post subject: Re: Sell Nanchang CJ6 aircraft parts |
call me 310 990 1111
