Aileron balance weights
Goto page 1, 2  Next
rmacpunk(at)netzero.net
PostPosted: Sat Mar 06, 2010 6:35 am    Post subject: Aileron balance weights Reply with quote
Has anyone put in an inspection panel to access the balance weights? My wing is not painted yet and don't wish to paint with the ailerons attached. Possible panel under weights or in lower wing tip. Ideas? Bob
bill.pagan(at)yahoo.com
PostPosted: Sat Mar 06, 2010 10:59 am    Post subject: Aileron balance weights Reply with quote
Haven't finished the upgrade yet (working on it) but was planning on an inspection panel same as under the bellcrank.
Bill Pagan
Sent: Sat, March 6, 2010 9:25:01 AM
Subject: Aileron balance weights
[quote][b][b]
countzero
PostPosted: Mon Mar 08, 2010 5:48 am    Post subject: Re: Aileron balance weights Reply with quote
Is there a reason why lead could not be used for the balance weight? It looks like a smaller lead weight could be extracted through the hole in the aft spar without removing the balance arm.
Rob
paulrod36(at)msn.com
PostPosted: Mon Mar 08, 2010 3:53 pm    Post subject: Aileron balance weights Reply with quote
Good God, man, have you lost your mind? Lead weights, just because they'd be smaller than steel ones? Don't you know that lead is EVIL?  The EPA  goes to great lengths to protect us from us, outlawing lead in gasoline, making pilots use 100 -low-lead, even so far as requiring handymen, remodelers and other such professions to go to training classes before they work on any house built before 1975 because they might have lead based paint in them. California has protected us from us by outlawing lead balance weights on cars. And you want to fly through the air, spreading your evil lead molecules over the peaceful bunnies, and Bambi, and itty bitty children? You fiend! Someone should report you to the Society For The Protection of Political Correctness before you go rampaging through our delicate planet, plotting who-knows-what. There's no telling what might happen if that lead weight were to fall off your plane, and bounce off an elementary school before sliding down a sidewalk in front of a convent, and ending up in a pond. That lead weight might leach out its lead into the aquifer, and might poison millions of people.    Somebody stop this man before he digs an oil well or builds a coal-fired electrical plant!!!  It's bad enough that Cessna, Beech and Piper use lead balance weights, now he wants to contaminate a Zenith.  Oh, the humanity.............
(Obviously, I don't have much to do today.)
Yeah, it would work pretty good.
Paul R
Subject: Re: Aileron balance weights
Date: Mon, 8 Mar 2010 05:48:46 -0800
--> Zenith601-List message posted by: "countzero" <robyboy(at)hotmail.com>
Rob
http://forums.matronics.com/viewtopic.php?p=289622#289622
&gt
DaveG601XL
PostPosted: Mon Mar 08, 2010 4:00 pm    Post subject: Re: Aileron balance weights Reply with quote
I made wingtip inspection panels when I originally built my 601 to access the strobe packs. I guess I will be able to also get to the counter-weight bolts to remove ailerons.
Dave
 Filesize:  104.99 KB
 Viewed:  26487 Time(s)
David Gallagher
Cincinnati, OH area
daveaustin2(at)primus.ca
PostPosted: Mon Mar 08, 2010 5:47 pm    Post subject: Aileron balance weights Reply with quote
Best note that I've read on here for quite a while!!
pbaker4(at)windstream.net
PostPosted: Tue Mar 09, 2010 5:13 am    Post subject: Aileron balance weights Reply with quote
I used lead on the inside of the tube to a depth of about 6 inches, then it only took a couple of plates to completely
balance the control. then I widened the opening in the rear
spar just a little bit. now if needed I can simply slide the
balance tube with weights on, no need for an inspection
plate. The wings are on and everything is hooked up .I will
be flying this week after a final weight and balance is done.
paul baker 601xl "the T model"
LHusky
PostPosted: Tue Mar 09, 2010 5:59 am    Post subject: Aileron balance weights Reply with quote
Paul, I would not mind seeing some pictures of that setup. Very Interesting
Larry Husky
Madras, Oregon
In a message dated 3/9/2010 5:13:54 A.M. Pacific Standard Time, pbaker4(at)windstream.net writes:
t href="http://www.matronics.com/Navigator?Zenith601-List">http://www.matronics.com/Navigator?Zenith601-List
ms.matronics.com/">http://forums.matronics.com
tp://www.matronics.com/contribution">http://www.matronics.com/contribution
PostPosted: Tue Mar 09, 2010 6:41 am    Post subject: Aileron balance weights Reply with quote
I see Paul signs his email with "The T model"
Was it ever officially decided what the "upgraded" 601's would be designated as? Don't recall seeing any final tally after we had the chance to vote.
Bill Pagan
Sent: Tue, March 9, 2010 8:12:52 AM
PostPosted: Tue Mar 09, 2010 11:45 am    Post subject: Aileron balance weights Reply with quote
Interesting question, Bill, far as I know there hasn't been an announcement.  I would think the simplest thing would be  to call it a 601XL-B, in keeping with other manufacturers' model series.
Paul R
Date: Tue, 9 Mar 2010 06:40:14 -0800
.ExternalClass DIV {;}
Bill Pagan
[/b][quote]
ronics.com
Louie928
PostPosted: Tue Mar 09, 2010 11:10 pm    Post subject: Re: Aileron balance weights Reply with quote
I did put an access hole under the aileron balance weights. It is 110mm x 220mm which is large enough for me to remove the weights to install or remove the weights. Also, a good idea to use lead and fewer plates so they can fit through a larger hole in the rear spar. Maybe a doubler around the larger hole would be advisable.
 Filesize:  65.77 KB
 Viewed:  26416 Time(s)
Louis W. Ott
601XL-B Corvair
dalemed
PostPosted: Wed Mar 10, 2010 7:17 am    Post subject: Re: Aileron balance weights Reply with quote
I was thinking of a similar approach but hadn't thought about putting lead inside the square tube. How did you do that?
Dale
Zenith Zodiac CH650
craig(at)craigandjean.com
PostPosted: Wed Mar 10, 2010 10:39 am    Post subject: Aileron balance weights Reply with quote
Lead has a very low melting point. I recall as a kid melting some old lead
plumbing fittings on a Coleman stove. But I would try hard to avoid any
fumes.
-- Craig
psm(at)att.net
PostPosted: Wed Mar 10, 2010 11:36 am    Post subject: Aileron balance weights Reply with quote
Hi guys,
I used to make, and sell, lead bullets in days gone by . . .
Lead melts around 700 degrees F. This is easily done on any kitchen stove
using a cast iron pan. I don't think it creates any vapor at temperatures
you can make with normal equipment so the fumes are not a problem.
On the other hand, if you get your lead from the junk yard it is covered
with all sorts of stuff that will create an unpleasant aroma when heated to
700 degrees.
Don't use an aluminum pot for this - it will melt and damage your stove.
Aluminum melts under 1000 degrees F.
For comparison, steel melts around 2000 degrees, and iron around 5000.
I wouldn't worry about melting the aluminum tube when pouring lead into it
since you will do this at close to 700 degrees. If you already have a bolt
or pin going thru the middle of the tube the lead will be held in place when
it hardens.
On my first aileron I only needed 4 of the steel plates to balance the whole
thing. This might be equivalent to a very small amount of lead. The
problem I see with the lead weights is mostly figuring out how much lead to
use before pouring it.
Good luck,
Paul
XL - installing upgrade kit
Z601c(at)anemicaardvark.c
PostPosted: Wed Mar 10, 2010 12:01 pm    Post subject: Aileron balance weights Reply with quote
On Wednesday 10 March 2010 13:36:57 you wrote:
Hi guys,
<snip>
The thing I do remember about lead is that it not only melts easily, it's easy
to spill. Boy, does it burn when it hits the skin!
Jim B. Belcher
BS,MS Physics
A&P/IA
General Radio Telephone Certificate
Instrument Rated Pilot
Retired Aerospace Technical Manager
Semi-proficient Househusband
n4546v(at)mindspring.com
PostPosted: Wed Mar 10, 2010 12:13 pm    Post subject: Aileron balance weights Reply with quote
" The problem I see with the lead weights is mostly figuring out how much
lead to use before pouring it."
Maybe this will help:
Steel weighs .283 Lbs per cubic inch
Brass weighs .307 lbs. per cubic inch
Lead weighs .409 lbs. per cubic inch
Need a trick to remember this?
Note all weights are Chevy engine displacements!
Randy, Las Vegas
PatrickW
PostPosted: Wed Mar 10, 2010 3:19 pm    Post subject: Re: Aileron balance weights Reply with quote
Where do you buy lead these days...?
Patrick
N63PZ
PostPosted: Wed Mar 10, 2010 4:02 pm    Post subject: Aileron balance weights Reply with quote
How about buying some lead shot at the gunsmith's and moulding it in epoxy
to the required shape.
Dave Austin
scottbevier
Bass Pro, and similar stores have all the lead you'll need.
Scott Bevier
601XL
PostPosted: Wed Mar 10, 2010 4:12 pm    Post subject: Aileron balance weights Reply with quote
Spruce sells "aviation grade" 1/8th inch lead sheet Smile
-- Craig
Goto page 1, 2  Next
Page 1 of 2
