jonlaury
Posted: Wed Mar 24, 2010 1:09 pm Post subject: Flap Motor lack of Oomph |
On start up, my long dormant flap motor can't overcome the drag of the linear actuator. The power supply gets pulled down to near zero volts, showing a couple of amps.
When I pulled the motor free of the actuator, it starts reluctantly for a second or so and then quickly spins up to full speed and torque. The actuator input shaft is easily turned by my fingers.
Is this a capacitor problem? I haven't pulled the motor apart yet.
John
enginerdy(at)gmail.com Guest
Posted: Wed Mar 24, 2010 3:01 pm Post subject: Flap Motor lack of Oomph |
Where are you taking the power supply measurement reading "near zero
volts"? ..and by power supply, do you mean the battery,
battery+alternator, bench supply, or something else?
--Daniel
On Wed, Mar 24, 2010 at 4:09 PM, jonlaury <jonlaury(at)impulse.net> wrote:
John
http://forums.matronics.com/viewtopic.php?p=291588#291588
Daniel Hooper
jonlaury
Posted: Wed Mar 24, 2010 5:40 pm Post subject: Re: Flap Motor lack of Oomph |
Daniel,
My bench power supply has analog meters for volts and amps. When I hook it up to the flap motor/linear actuator, the voltmeter almost pegs 0 volts.
John
Posted: Wed Mar 24, 2010 6:13 pm Post subject: Flap Motor lack of Oomph |
John,
It sounds like your bench supply might have a lack of "oomph". Try
connecting it to a battery. Use a fuse in series with it to prevent
smoke, just in case you have a dead short across the motor. Good luck!
Daniel Hooper
Neal.George(at)hurlburt.a Guest
Posted: Thu Mar 25, 2010 6:58 am Post subject: Flap Motor lack of Oomph |
John -
Which power supply are you using, and what does the amp meter indicate when
the voltage is sagging toward the peg?
neal
Daniel,
John
smime.p7s |
5.09 KB |
410 Time(s) |
jonlaury
Posted: Thu Mar 25, 2010 8:08 am Post subject: Re: Flap Motor lack of Oomph |
Daniel, thanks for that. I'll check out the motor/actuator with a charged battery today.
Neal, the power supply brand escapes me right now, but when the volt meter pegs, the amp meter shows approx 2 amps. I'll report back with the PS brand tonight.
Bob McC
Posted: Fri Mar 26, 2010 6:50 am Post subject: Flap Motor lack of Oomph |
Normal 0 false false false <![endif]--> <![endif]--> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} <![endif]-->
I'll suggest that if the power supply is only capable of delivering a maximum of 2 Amps at zero volts then it is not nearly robust enough to properly run a flap motor. Try a fully charged battery or a power supply capable of supporting a 5 or 10 Amp load at 12 Volts and see if your test results are any different. I suspect that with an adequate supply your motor will run normally.
Bob McC
[quote] --
_________________ Bob McC
Falco #908
(just starting) |
jonlaury
Posted: Fri Mar 26, 2010 7:10 am Post subject: Flap Motor lack of Oomph |
The Power Supply is an Astron RS-35M , 13.8v, 25 amps continuous (at) 50% duty cycle. American made in Irvine CA
Daniel was right. It's not a flap motor problem. The motor perked right up when connected to my car battery.
Anyone have ideas re the power supply? There was an incident where the positive and negative alligator clips contacted each other. But the 8 amp fuse of the PS didn't blow so I thought everything was OK.
J
bgray(at)glasair.org Guest
Posted: Fri Mar 26, 2010 7:24 am Post subject: Flap Motor lack of Oomph |
Don’t rule out the motor until you read the amperage draw with a meter.
Bruce
www.Glasair.org
jonlaury
Posted: Fri Mar 26, 2010 11:24 am Post subject: Re: Flap Motor lack of Oomph |
Thanks Bruce. I'll try that today.
Talked to Astron and relayed the problem. The guy directed me to the circuit board in the unit to replace one of the resistors with a higher value one.
It's all kind of wierd, because this thing has worked flawlessly in the past on this same motor. The last time I used it, the outputs contacted, but the fuse didn't blow and the unit still worked fine.
The literature on their website says that the unit is protected from this kind of event.
ulflyer(at)verizon.net Guest
Posted: Sat Mar 27, 2010 11:35 pm Post subject: Flap Motor lack of Oomph |
Sounds like you may have a lab type bench power supply, many of these also have a current limit setting control. May be a smaller knob on one of the larger knobs or separate, and turn like a volume control. It could be set to limit the amount of current the power supply would supply for testing/design applications.
jerb
At 08:05 AM 3/26/2010, you wrote:
[quote]The Power Supply is an Astron RS-35M , 13.8v, 25 amps continuous (at) 50% duty cycle. American made in Irvine CA
J
jonlaury
Posted: Mon Mar 29, 2010 7:01 am Post subject: Flap Motor lack of Oomph |
Jerb,
I'll look into that but it has powered the same motor in the past without a problem.
John
