jridgway
Posted: Sat Apr 17, 2010 5:13 pm Post subject: rotary oil cap vent |
Hi, Just checked my rotary valve oil bowl cap(582). It has a small hole in the cap, however, it seems that there is a sealed paper/ rubber gasket inside the cap.
This gasket does not have a hole in it. How is this working?
Jack
Guy Buchanan
Posted: Mon Apr 19, 2010 2:15 pm Post subject: rotary oil cap vent |
At 06:13 PM 4/17/2010, you wrote:
| Quote: | Hi, Just checked my rotary valve bowl cap. It has a small hole in
Jack,
Hopefully the gasket does have a hole in it, you just can't
see it. The hole is a slit in the rubber, about .1" long, nothing
more. If it has no hole in it you probably already noticed the
results, which will either be rotary valve oil spewed out somewhere,
a grossly enlarged rotary valve oil tank, or oil in your coolant.
Yes, the cap should be, very slightly, vented.
Guy Buchanan
San Diego, CA
K-IV 1200 / 582-C / Warp / 400 hrs. and counting
Deceased K-IV 1200
A glider pilot too. |
jridgway
Posted: Tue Apr 20, 2010 11:38 am Post subject: Re: rotary oil cap vent |
thanks..I will check it in the next few days..Jack
