Fergus Kyle
Joined: 03 Jun 2007 Posts: 291 Location: Burlington ON Canada
Posted: Tue Mar 09, 2010 1:23 pm Post subject: rudder cable hint |
For those as slow as I am, I have been cutting rudder cable with everything but the paper scissors and ended up whacking a cold chisel against a steel table to cut the stuff, when my infuriating best neighbour said, “why don’t you just visit the local bicycle shop? I bet they cut cable all day long”.
They do, and with a neat pair of cutters that do a superb job. I could kill him.
Ferg [quote][b]
christoph.both(at)acadiau Guest
Posted: Tue Mar 09, 2010 2:13 pm Post subject: rudder cable hint |
Us e Dremel tool with a cut off wheel. Works like a charm. You won’t believe how clean the cut is! Wear safety glasses.
Christoph
#223
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Fergus Kyle
Sent: Tuesday, March 09, 2010 5:17 PM
To: EUROPALIST
Subject: rudder cable hint
Ferg | Quote: | | http://www.matronics.com/Navigator?Europa-List | 0123456789
Posted: Tue Mar 09, 2010 2:23 pm Post subject: rudder cable hint |
Hi! Ferg
So what is wrong with a slim cutting disc on a Dremel type tool?
Bob Harrison.
Sent: 09 March 2010 21:17
To: EUROPALIST
Subject: Europa-List: rudder cable hint
Ferg 0123456789
topglock(at)cox.net Guest
Posted: Tue Mar 09, 2010 2:24 pm Post subject: rudder cable hint |
Wrap the cable with tape at the point you want to cut it. Place it on
an anvil, center a sharp cold chisel on the tape and whack it. Done deal!
Jeff - Baby Blue
On 3/9/2010 4:12 PM, Christoph Both wrote:
| Quote: | Us e Dremel tool with a cut off wheel. Works like a charm. You won’t
Christoph
#223
[mailto:owner-europa-list-server(at)matronics.com] *On Behalf Of *Fergus Kyle
*Sent:* Tuesday, March 09, 2010 5:17 PM
*To:* EUROPALIST
*Subject:* rudder cable hint
kill him.
Ferg
*http://www.matronics.com/Navigator?Europa-List*
*http://forums.matronics.com*
*http://www.matronics.com/contribution*
Checked by AVG - www.avg.com
mikenjulie.parkin(at)btin Guest
Posted: Wed Mar 10, 2010 1:20 am Post subject: rudder cable hint |
For those builders that want control cable cutters, I have a pair of CK
cutters (CK TOOLS T3744, 190mm AIRCRAFT CABLE & WIRE ROPE CUTTER), they have
worked perfectly. They are not very expensive and are readily available.
See the attached ebay link. A google search showed plenty of suppliers on
both sides of the pond.
http://cgi.ebay.co.uk/CK-TOOLS-T3744-190mm-AIRCRAFT-CABLE-WIRE-ROPE-CUTTER_W
0QQitemZ180478517950QQcmdZViewItemQQptZUK_Hand_Tools_Equipment?hash=item2a05
5ba2be
regards,
