rparigoris
Posted: Fri Feb 26, 2010 3:14 pm Post subject: How do you reliably attach wire to a solder lug switch |
Hi GroupAgain I wish my instrument was "just a little bit larger". I need to install a switch to reset (or turn off) my wastegate servo for Rotax 914. It is not somewhere I want a wire fatiguing and breaking. Rotax calls for a switch DPDT NO with momentary (OFF). I want ability to keep off so instead I want to use a TPDT, this way when off I can illuminate a warning LED. The real estate I want to place switch and indicator allows use of a miniature toggle with solder lugs (also Perihelion switch guard and red screw on boot cover). My question is what can I do besides double heat shrinking lugs and wires to decrease chance of a mechanical fatigue failure? Or is double heat shrink with wires secured within 2" adequate?Thx.Ron Parigoris [quote][b]
