Liberty XL Service Bulletin for Canopy Shoot Bolts
rampil
PostPosted: Sun Feb 21, 2010 12:16 pm    Post subject: Liberty XL Service Bulletin for Canopy Shoot Bolts Reply with quote
Hi All,
I found this recent document on the US NTSB website.
It seems Liberty has had a few (6) A/C lose doors in flight, just like
the early Europas (at least I have not heard of a door flying off
in flight in several years).
These episodes,the NTSB says were all apparently due to improper
shoot bolt deployment into the rear socket and failure to check
by crew.
Since the Europa latch system is quite similar, we may have a lesson
to learn here at someone else's expense!
Does anyone have any comment?
LibertySBonRearDoorLatchPin.pdf
Liberty SB published on NTSB.gov
 Filename:  LibertySBonRearDoorLatchPin.pdf
 Filesize:  218.43 KB
 Downloaded:  388 Time(s)
Ira N224XS
n914va(at)bvunet.net
PostPosted: Sun Feb 21, 2010 12:52 pm    Post subject: Liberty XL Service Bulletin for Canopy Shoot Bolts Reply with quote
I learned to fly in a Piper Tomahawk which used a similar system to secure
the doors. It was pounded into my head to check both doors very carefully
before taking of. On my long solo cross country I left Harrisburg
International and as I turned to leave the pattern, I noticed more noise
than usual. Sure enough the rear shoot bolt on my side was not engaged. I
slowed to 10 knots above stall and trimed for level flight as instructed and
was able to correctly shut the door. I was prepared to request permission
and land back at Harrisburg had I not been successful because of the dire
warnings from my instructor about not bringing the complete airplane home.
Learning a lesson without dire consequences is most preferable. Learning
from others mistakes is even better for you.
Vaughn Teegarden
A191 back in the building stage
air.guerner(at)orange.fr
PostPosted: Mon Feb 22, 2010 5:00 am    Post subject: Liberty XL Service Bulletin for Canopy Shoot Bolts Reply with quote
Hi Ira,
The problem often comes from the pilot opening the door to cool the cockpit or demist the windscreen at the last minute (possibly after having performed the pre-takeoff check)
and failing to re-lock it properly.
My suggestion:
1. Check doors locked (both pins engaged) during your pre-takeoff check (I assume everybody does this!)
2; Never open a door after having performed your pre-takeoff check, unless absolutely necessary (in that case double check door properly locked)
A few decades ago I experienced a side window popping open during takeoff in a Cessna 150. The noise and the wind were frightening! The key here is to fly the airplane first and deal with the door or window second.
Best regards
Remi Guerner
F-PGKL
<<<<These episodes,the NTSB says were all apparently due to improper
by crew.>>>>>>>
