How to ground rempte mounted VDO oil pressure gauge.
rparigoris
PostPosted: Wed Feb 17, 2010 7:12 am    Post subject: How to ground rempte mounted VDO oil pressure gauge. Reply with quote
Hi BobThx. for the reply. How is the sender electrically connected, and how is the sender mechiasnically mounted to your bracket?Thx.Ron Parigoris"> I mounted my oil pressure sensor on a piece of aluminum angle that was > bolted to the top of the passenger foot well. Ran a 20 ga black wire from > one of the mounting bolts up to the firewall ground block. 20 ga is way > overkill, but it's what I had on hand and the 0.1 oz of extra weight > didn't seem like too great a penalty." [quote][b]
rparigoris
PostPosted: Wed Feb 17, 2010 7:57 am    Post subject: How to ground rempte mounted VDO oil pressure gauge. Reply with quote
Hi Bob"Here's where the installation of the remote sensor installation is documented: http://www.europaowners.org/forums/gallery2.php?g2_itemId=67636"It appears you may have tapped your aluminium bracket and that is how you are getting electrical ground to the mounting bracket mounting screw? Did you perhaps put a thin nut between sender and bracket? Perhaps a spacer that sandwisches the sender and bracket to make the electrical connection?Thx.Ron Parigoris [quote][b]
