jonathan(at)entry.co.za Guest
Posted: Sun Feb 14, 2010 10:24 pm Post subject: Landing gear turn around |
Hi all wise ones,
I have 601XL with 183Hrs on the hobbs. I am busy with the upgrade, and
decided to turn the gear around, flat side forward. I am hoping that the
transistion to flight would be smoother, and I will be able to hold the nose
gear off, for longer when landing. We have many very rough fields that we
land on, and I have bottomed out the nose gear on several occasions.
I believe that the latest plans call for the gear installed this way in
anycase. Could someone please confirm this, as my plans are rather old. Now
that I have turned the gear around, I tested it by standing on the step, and
well, now it tips onto it's tail. Now unfortunately I did not test this,
before turning the gear around. What I am trying to say is, is this going to
be a problem, as I currently have the wings off, the prop off, and the spar
carry thru is completely out of the plane. All of these components are in
front of the gear CoG.
Is there anyone out there with the wings off, and still has the landing gear
flat side to the rear, that can stand on the step, to see if it tips
backwards. Any help would be appreciated, as I would rather put the landing
gear back, before I put the wings back on.
Thnx
Jonathan Starke
psm(at)att.net Guest
Posted: Sun Feb 14, 2010 10:37 pm Post subject: Landing gear turn around |
Hi Johnathan,
My copy of the plans shows the flat side forward. There is not a problem standing on the step with the engine and wings installed.
I think you will find the nose a lot lighter on the ground with the gear installed this way.
Paul
Camas, WA
Awaiting upgrade kit.
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of jonathan(at)entry.co.za
Sent: Sunday, February 14, 2010 10:23 PM
Subject: Landing gear turn around
Hi all wise ones,
Thnx
Jonathan Starke
vk3eka(at)bigpond.net.au Guest
Posted: Sun Feb 14, 2010 10:42 pm Post subject: Landing gear turn around |
Jonathan,
I have my gear flat side forward (correct according to my 2008 plan set).
My wings are off at the moment. I do have the prop, O-200 and the center section in and can’t say I noticed any tipping.
I can check tomorrow when I get to the hangar if you like. Can’t help with the flat side to the rear though.
Cheers
Peter
Wonthaggi Australia
http://zodiac.cpc-world.com
Sent: Monday, 15 February 2010 5:23 PM
Hi all wise ones,
Thnx
Jonathan Starke
| Quote: | | http://www.matronics.com/Navigator?Zenith-List | 0123456789
Posted: Sun Feb 14, 2010 10:52 pm Post subject: Landing gear turn around |
This will be great Peter, the only difference then will be the motor weight, I have a Rotax 912S, but if you see no tipping with the wings off, then I should be OK. (Maybe need to go on a diet as well, but that is another issue!)
Jonathan
rogers_pritchard(at)yahoo Guest
Posted: Sun Feb 14, 2010 11:36 pm Post subject: Landing gear turn around |
Johnathan,
I have the wings, canopee & center spar out of my ac and it squated no more than 2" when I just put my 200 pounds on the step.
Roger
--- On Mon, 2/15/10, jonathan(at)entry.co.za <jonathan(at)entry.co.za> wrote:
From: jonathan(at)entry.co.za <jonathan(at)entry.co.za>
Date: Monday, February 15, 2010, 1:23 AM
Hi all wise ones,
Thnx
Jonathan Starke
el=nofollow target=_blank>http://www.matronics.com/Navigator?Zenith-List
et=_blank>http://forums.matronics.com
jaybannist(at)cs.com Guest
Posted: Mon Feb 15, 2010 5:34 am Post subject: Landing gear turn around |
Jonathan,
My landing gear has the flat side facing forward, Corvair engine up front. If two average size guys step on the boarding steps at the same time, the tail will tip down. Otherwise, no problem.
Jay Bannister
Posted: Mon Feb 15, 2010 7:34 am Post subject: Landing gear turn around |
Great news, so I should have no problems either.
Thnx
Jonathan
Posted: Tue Feb 16, 2010 11:01 am Post subject: Landing gear turn around |
Jonathan,
I jumped up and down on the step today and nothing happened. It was very stable.
Have fun!
Cheers
Peter
Sent: Monday, 15 February 2010 5:52 PM
Subject: Re: Landing gear turn around
Jonathan
----- Original Message -----
To: zenith-list(at)matronics.com (zenith-list(at)matronics.com)
Sent: Monday, February 15, 2010 8:37 AM
Subject: RE: Zenith-List: Landing gear turn around
Jonathan,
Cheers
Peter
Wonthaggi Australia
Hi all wise ones,
Thnx
Jonathan Starke
| Quote: | | http://www.matronics.com/Navigator?Zenith-Listhttp://forums.matronics.comhttp://www.matronics.com/contribution href="http://www.matronics.com/Navigator?Zenith-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.comhref="http://www.matronics.com/contribution">http://www.matronics.com/c | | 0123456789 | Quote: | | http://www.matronics.com/Navigator?Zenith-List | 0 | Quote: | | http://www.matronics.com/Navigator?Zenith-List | 1 | Quote: | | http://www.matronics.com/Navigator?Zenith-List | 2 | Quote: | | http://www.matronics.com/Navigator?Zenith-List | 3 | Quote: | | http://www.matronics.com/Navigator?Zenith-List | 4 | Quote: | | http://www.matronics.com/Navigator?Zenith-List | 5 | Quote: | | http://www.matronics.com/Navigator?Zenith-List | 6 | Quote: | | http://www.matronics.com/Navigator?Zenith-List | 7 | Quote: | | http://www.matronics.com/Navigator?Zenith-List | 8 | Quote: | | http://www.matronics.com/Navigator?Zenith-List | 9
kkinney
Posted: Tue Feb 16, 2010 5:34 pm Post subject: Re: Landing gear turn around |
Just a minor data point - When I flew in a Factory build XL, I was specifically warned about allowing 2 people from stepping up at the same time.
In case this happens, the factory has a skid that prevents the tie-down from hitting the ground. It looks like they expected 2 people to try to step up at the same time.
I wouldn't worry about it.
Kevin Kinney
