tailpost repair with stiffeners
Jimmy Young
PostPosted: Sun Feb 14, 2010 3:44 pm    Post subject: tailpost repair with stiffeners Reply with quote
List,
Here's what I ended up doing after cracking my tailpost assembly. I think adding the stiifener struts will help strengthen that area, thanks for the advice I received. I used some 1/8" x 1" Home Depot Aluminum bar stock and put an AN3 bolt through the tail ring, & used the existing tailwheel rod connector bolt location for the bottom.
I also flew about 2 hours today, first time to get high in quite a while. I did a lot of touch & goes with a moderate direct crosswind blowing just to brush up a bit. I came to the conclusion I needed some practice after I first flew over to LBX (Lake Jackson TX) to get some avgas. There was maybe a 10 mph direct crosswind and of course I'm landing on asphalt. I felt like a beginner. That asphalt grabbed my tires & I got a little squirrelly, probably felt worse than it looked I hope. Big difference between grass & asphalt with a crosswind!
Have a good one -
 Filesize:  150.63 KB
 Viewed:  1934 Time(s)
 Filesize:  144.42 KB
Jimmy Young
Missouri City, TX
Kolb FS II/HKS 700
