LarryRosen
Posted: Mon Apr 10, 2006 1:48 pm Post subject: Sun-N-Fun my comments |
It was great to get down to Sun-N-Fun. In the past there was not much
there and one day was enough, but now that I am building the two days
was just not enough. Too much to do and see. You can see some of my
photos here <http://lrosen.nerv10.com/Construct/SunNFun_2006/index.html>.
There were 3 customer built RV-10 at the show when I was there.
Unfortunately I did not get t a close look at the TruTrak RV. But both
Vic and Tim 10s are great looking. A special thanks to Tim for letting
me sit in the pilots seat while he turned on the Cheltons and avionics.
I sat there making airplane noises and dreaming I was flying my
completed 10.
As you know Tim's panel is has the Cheltons side by side and Vic's are
up and down, and both would not change the layout. After sitting in
Tim's plane, side by side works best for me. It sure is great to have
the flexibility to make your own choice and put the plane together as
you want.
I had thought that I would put inertial reals in for the seat belts.
But with the Tims seat belts on tight I could easily reach the panel and
the avionics stack over to the right. Vic's Crow Enterprizes belts with
the rotary latch look very comfortable. For me it will be fixed belts,
but the wider hooker or crow type with rotary latches.
Paint cracking happens where the windows meet the fiberglass canopy.
Vic suggested putting e-glass around the exterior of the window which
may stop or reduce the cracking.
Vic has his oxygen bottle mounted between the passenger seats. It
looked like a good place to mount it in lieu of hanging in on the
co-pilot seat
<http://lrosen.nerv10.com/Construct/SunNFun_2006/Vic%20RV10/slides/2006-04-07-SnF-25.html>.
Cirrus has a similar install. If anyone can take a picture of the
Cirrus O2 installation and email them to me, it would be greatly
appreciated.
Accuracy Avionics has an overhead console for the 10. I bought one. I
have pictures and comments on my web site you can see them here
<http://lrosen.nerv10.com/Construct/SunNFun_2006/Overhead/index.html>.
Tony and Eric have put together a nice product. It has six cockpit
lights for the pilot & co-pilot, rear passengers and the baggage area.
Four vents for overhead ventilation and a bar to hang clothing in the
baggage area. A scoop mounts to the intersecting fairing and scat tubes
connect to the overhead console to pressurize it. There is an area to
mount an overhead DVD player that flips down (cool). The package comes
in 3 flavors. Basic, standard and deluxe. List price is $1,295,
$2,295, and $2,495 respectively. The basic is the console straight from
the mold and primed. Standard adds the DVD player, six cockpit lights
and 4 eyeball vents. Deluxe adds installation of the components
including the nut plates & seal. I bought the standard. Tony and Eric
are also putting together a center console and a variety of fiberglass
panels. I cannot wait to see the rest of their offerings.
Contact information is: Tony Sustare, Accuracy Avionics, 63020 Powel
Butte Highway, Suite 1, Bend, Oregon 97701
Phone 866/KIT-PANL email: TonyS at accuracy avionics dot com
Josh from Direct2 had the Chelton SV-10 wire harness there. It looked
complete and well put together, but it was hard to tell with everything
curled up. They even have mounts for the GADAHRS and magnetometer
Hopefully the wire harness will ship to me soon. Chelton is working on
integrating XM weather in addition to WSI weather to give you a choice.
Avionics Systems <http://www.avionikits.com/> has a modular molded
fiberglass panel that allows the avionics stack to be located anywhere
on the panel. They has a system on display with the avionics stack to
the right of the center rib. If anyone has a photo of this panel please
email it to me.
Advanced Flight Systems new EFIS & Engine monitoring graphics are
outstanding. Grand Rapids better watch out. Currently the AFS system
does not have all the functionality as the GRT system, but with the
better screen it has the potential to blow away the GRT and challenge
the Chelton systems. But, this will be too late for me.
TruTrak is also entering the EFIS marked, but not much info on there
system. Maybe at OSH. They did announce a RV-10 autopilot. I guess it
positioned somewhere between the Sorcerer and Digiflight IIVSGV.
Plane Power's development of a vacuum pad mounted alternator is not
going to happen in the near future. They are working on STC's for their
existing products. They want the alternator to work at low engine RPM
settings and that will take a while.
E-Mag/P-Mag was not at the show. Sure wish they were. I need to make a
decision on an ignition system.
Sorry for the long email. There is probably more that I forgot. Any
comments or additional observations would be appreciated.
Larry Rosen
RV-10 #356
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
johncleary(at)mangertonns Guest
Posted: Mon Apr 10, 2006 2:59 pm Post subject: Sun-N-Fun my comments |
Larry,
This is a wonderfully informative account for those of us who live on the
other side of the globe.
Thank you,
John and Jennifer Cleary
(Completing fairings on empennage)
Tdawson(at)avidyne.com Guest
Posted: Mon Apr 10, 2006 6:11 pm Post subject: Sun-N-Fun my comments |
Larry:
What were the prices on the 3 flavors of overhead panel?
TDT
LarryRosen
Posted: Mon Apr 10, 2006 6:24 pm Post subject: Sun-N-Fun my comments |
From below
The package comes in 3 flavors. Basic, standard and deluxe. List price is $1,295,
Larry
Tim Dawson-Townsend wrote:
[quote]Larry:
TDT
#40356
N205EN (reserved)
<http> |
Tim(at)MyRV10.com Guest
Posted: Mon Apr 10, 2006 6:43 pm Post subject: Sun-N-Fun my comments |
Larry,
I think Tim;s (TDT's) problem was that he speaks French, so
he didn't understand it the first time. Here, let me
help...
Le packet entre 3 parfums. Fondamental, standard et de luxe. Le prix de
liste est $1.295, $2.295, et $2.495 respectivement.
(All in good humor)
Larry Rosen wrote:
From below
is $1,295, $2,295, and $2,495 respectively.
Larry
> Larry:
> Thanks,
> TDT
> do not archive
LarryRosen
Posted: Mon Apr 10, 2006 6:55 pm Post subject: Sun-N-Fun my comments |
WOW, he has a full time job, a flying RV-10, a killer web site, doesn't
sleep at night and speaks French.
Tim Olson wrote:
Larry,
help...
de liste est $1.295, $2.295, et $2.495 respectivement.
(All in good humor)
#40356
N205EN (reserved)
<http> |
Posted: Mon Apr 10, 2006 6:57 pm Post subject: Sun-N-Fun my comments |
Hey, golly, there's this scroll bar thingy here and if you move it, more words show up!
I prefer:
Das Pauschalangebot hat drei Arten. Einfach, Standardmaessig, und Luxus. Der Listenpreis steht beziehungsweise bei $1,295, $2,295, und $2,495.
TDT
johnwcox(at)pacificnw.com Guest
Posted: Mon Apr 10, 2006 7:53 pm Post subject: Sun-N-Fun my comments |
Paint cracking is a well documented problem with a clear solution in the
Lancair community. That subject will get some coverage in the next week
or two.
John - $00.02
glastar(at)gmx.net Guest
Posted: Mon Apr 10, 2006 9:00 pm Post subject: Sun-N-Fun my comments |
Hi Tim,
this time bablefish goofed a bit, not as much as on the French but hey that's limitation it is what did we do before the Internet?
Werner
Tim Dawson-Townsend wrote: [quote] [quote]Hey, golly, there's this scroll bar thingy here and if you move it, more words show up! I prefer: Das Pauschalangebot hat drei Arten. Einfach, Standardmaessig, und Luxus. Der Listenpreis steht beziehungsweise bei $1,295, $2,295, und $2,495. TDT do not archive --
Posted: Mon Apr 10, 2006 9:28 pm Post subject: Sun-N-Fun my comments |
Unfortunately that's my own rusty German, not machine-translated!
TDT
40025
k5wiv(at)amsat.org Guest
Posted: Tue Apr 11, 2006 1:24 am Post subject: Sun-N-Fun my comments |
Not to mention (based on the SnF photos) a lovely spouse and two cute kids!
GRANSCOTT(at)aol.com Guest
Posted: Tue Apr 11, 2006 4:41 am Post subject: Sun-N-Fun my comments |
In a message dated 4/10/2006 5:50:33 PM Eastern Standard Time, LarryRosen(at)comcast.net writes:
| Quote: | I guess it
positioned somewhere between the Sorcerer and Digiflight IIVSGV |
Tim, I spent a few minutes with the guys at TruTrak...they said the new RV10 AP does every thing the Sorcerer does except intercept approaches...and that they would unveil the new screen with details at OSH...someone at another screen shop said the new screen would be a rather simple screen and not at complete at the Chilton system...but probably only time will tell---see you at OSH...sorry to have missed meeting up with you all.
Patrick
Posted: Tue Apr 11, 2006 6:22 am Post subject: Sun-N-Fun my comments |
Patrick, I presume you meant to write this autopilot does everything except intercept an ILS – presumably a GPS approach would be a piece of cake.
TDT
40025
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of GRANSCOTT(at)aol.com
Sent: Tuesday, April 11, 2006 8:39 AM
Subject: Re: Sun-N-Fun my comments
I guess it
Patrick
Posted: Tue Apr 11, 2006 6:58 am Post subject: Sun-N-Fun my comments |
Sorry TDT you're correct...they do not have it on the web site as of last week, and other than a pix they did not have a data sheet, that I was aware of, so the fellow said that it would not intercept the final approach course...I was assuming he meant an ILS and not a GPS/WAAS approach...but I'm not really sure that is correct.
Hopefully they will have it on the site soon.
P
bsponcil(at)belinblank.or Guest
Posted: Tue Apr 11, 2006 8:55 am Post subject: Sun-N-Fun my comments |
Larry,
Did you happen to see the new bluemountain geneation 4 EFIS? If you did,
I'd be interested in your impressions. It looks pretty nice on their
brochure (but then what product doesn't). I doubt I'll have the cabbage to
go with double Cheltons so I'm going to have to decide between GRT, BMA and
AFS.
-Brian
#40497
N211BD
Iowa City, IA
CJohnston(at)popsound.com Guest
Posted: Tue Apr 11, 2006 9:45 am Post subject: Sun-N-Fun my comments |
Hey all -
Is there a way to get air into the overhead panel without putting an
inlet on the intersection fairing? Does that inlet on the fairing seem
like a bummer to anyone else? I really like the look of the overhead
panel though. What is the difference between the 3 flavors? Anyone?
cj
#40410
wings
www.perfectlygoodairplane.net
Posted: Tue Apr 11, 2006 10:02 am Post subject: Sun-N-Fun my comments |
Do like I did and scroll down the message a little farther . . .
TDT
jesse(at)itecusa.org Guest
Posted: Tue Apr 11, 2006 10:12 am Post subject: Sun-N-Fun my comments |
I would think that you would get a lot of water in the system with that
scoop back there. You could with the normal vents too, but with them
closed, the water won't be able to get in an fill up a scat tube or
anything. I would think there would have to be a way to close up the scoop
if nothing else. The overhead panel looks great, though. Now, to figure
out a way to do that myself without forking out the $1,300....or just do
without it.
Do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
I'm in Ecuador right now and should be back in the country by the end of
May. You may call me at 352-505-1899 and leave a message that I can check
from down here. Any I-TEC questions can be directed to the I-TEC office at
352-465-4545.
Yes, it does seem like a bummer to have that air inlet there and it looks
much too large for air moving at say 180mph or more. (Drag bucket) I also
wonder whether the propeller swirl (P-factor)will cause some of the exhaust
gasses to find there way up into that air scoop.
I also wonder about moisture.
The overhead does look great however.
John G. #409
No not archive
[quote]From: "Chris Johnston" <CJohnston(at)popsound.com>
Subject: RE: Sun-N-Fun my comments
Date: Tue, 11 Apr 2006 10:44:36 -0700
Hey all -
cj
#40410
wings
Posted: Tue Apr 11, 2006 10:26 am Post subject: Sun-N-Fun my comments |
cj,
To your point about the inlet fairing, all I can add is that the
people looking into the air pressures at various part so
of the fuselage seem to have some experience in these matters and
they determined that a standard flush NACA may not have enough
pressure to provide the air pressure in the chamber. They thought
it may possibly even provide a vacuum instead of pressure, so
they designed a scoop that would get into the airstream and
provide some positive pressure. Like anything, there are tradeoffs,
such as drag, but the comfort has value too. I don't think it will
look bad when done at all.
[quote] --
