PaulR
Posted: Sun Feb 07, 2010 3:40 pm Post subject: RS-232 |
I'm wiring up my panel and was getting ready to hook the Dynon D-100 serial output to the GTX-327. Reading the wiring diagram for the Garmin, it says to hook the TX wire from the Dynon to a certain pin.(I forgot which number) and that the RS-232 GND to either of two chassis grounds on the Garmin. I take that to mean that the RS-232 gnd should be at the same potential as the rest of the 12V grounds and could be connected to the "forrest of tabs" where the balance of the grounds are hooked.
If that's true, then couldn't all the RS-232 gnds be connected there, along with their respective shields?
Am I thinking this through correctly?
_________________ Paul Rose
N417PR
RV-9A |
Posted: Sun Feb 07, 2010 6:00 pm Post subject: RS-232 |
At 05:40 PM 2/7/2010, you wrote:
SIGNAL grounds are different and sometimes separate of
POWER grounds. The forest-of-tabs is for the grounding
of electrical accessories. When it comes to wiring
components of a radio, navigation or other electronics,
follow the instructions. SIGNAL grounds are like the
grounds for microphones, headsets, etc and are given
specific treatment. See the documentation on the DIY
audio isolation amplifier on my website for examples.
