Fwd: Possible mistake upper spar cap CH 750 75-W-2 Illustrat
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Zenith750-List
joemotis(at)gmail.com
PostPosted: Sun Feb 07, 2010 4:06 pm    Post subject: Fwd: Possible mistake upper spar cap CH 750 75-W-2 Illustrat Reply with quote
---------- Forwarded message ----------
From: joe motis <joemotis(at)gmail.com (joemotis(at)gmail.com)>
Date: Sun, Feb 7, 2010 at 3:09 PM
Subject: Fwd: Possible mistake upper spar cap CH 750 75-W-2 Illustration 2 Angle dimension given is 40 mm should be 52 mm?
To: joe motis <joemotis(at)gmail.com (joemotis(at)gmail.com)>
Hi Listers,
I am building the wing spars and I made both upper spar caps with a 40 mm diimension on the angle cut end. It does not fit the way it is supposed to. The actual measurement needs to be 52 mm. The 80 mm up and 272 mm over dimension have both been checked and are correct for the spar angle.
Anyone else have this issue?.
Page 75-W-2 Illustration 2 Upper spar cap
Joe Motis
CH 750 WW Corvair
- The Matronics Zenith750-List Email Forum -
http://www.matronics.com/Navigator?Zenith750-List
 Filesize:  336.22 KB
 Viewed:  4145 Time(s)
ifly4fun2(at)sbcglobal.ne
PostPosted: Mon Feb 08, 2010 4:54 am    Post subject: Fwd: Possible mistake upper spar cap CH 750 75-W-2 Illustrat Reply with quote
Joe,
Great catch and likely only something a scratch builder would have caught. I'm not as far a long as you are but I've made note to cut the upper spar cap angle using the web as the guide. Thank you for passing along your finding.
Art
Wichita, KS
To: zenith750-list(at)matronics.com
Date: Sunday, February 7, 2010, 5:11 PM
From: joe motis <[url=/mc/compose?to=joemotis(at)gmail.com]joemotis(at)gmail.com[/url]>
To: joe motis <[url=/mc/compose?to=joemotis(at)gmail.com]joemotis(at)gmail.com[/url]>
Hi Listers,
Joe Motis
CH 750 WW Corvair
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Zenith750-List All times are GMT - 8 Hours
