S700-2-50 switch function
airelectricjim
PostPosted: Fri Feb 05, 2010 1:13 pm    Post subject: S700-2-50 switch function Reply with quote
My circuit requires a DPDT "on-on-(on)" switch action with a
make-before-break between center and momentary positions. Does the
S700-2-50 switch fulfill the make-before-break requirement? If it doesn't, do you know of a source for such a switch?
Thanks for all your help via the Aeroelectric list. I'm a loyal lurker.
Blue skies and tailwinds
Jim
CH-801
DeltaHawk diesel
90% done 99% left
Jim
Zenith CH801
DeltaHawk diesel
jmcburney@pobox.com
PostPosted: Fri Feb 05, 2010 6:32 pm    Post subject: S700-2-50 switch function Reply with quote
At 03:09 PM 2/5/2010, you wrote:
The switch mechanism is a "teter-toter"
rocker that can only break the present connection
long before the open contacts close. I'm
not aware of any toggel switch that would operate
any differently.
PostPosted: Sat Feb 06, 2010 8:13 am    Post subject: Re: S700-2-50 switch function Reply with quote
Jim,
Perhaps additional components can be used to delay opening of the DP3T switch contacts while switching from one position to another. A large capacitor might help, depending on the current of the load. Or a relay can be used with its contacts in parallel with the DP3T contacts. See the attached sketch. http://tinyurl.com/ya5zkkv
If you post a copy of your schematic, others can offer suggestions.
Joe
 Filesize:  45.96 KB
 Viewed:  4348 Time(s)
Joe Gores
