Jeff(at)rmmm.net Guest
Posted: Tue Feb 02, 2010 3:19 pm Post subject: Voltage drop |
Hi Guys,
last month I noticed my voltage slowly dropping to under 10 volts . It
has been reading inconsistent for the last two flights so after 220
hours I replaced the Regulator. Now it's consistent but I'm only
getting 11 volts on my stratomaster engine monitor. If anyone has a
quick place for me to look I would like to hear from you.
Best Regards,
Jeff R. N128LJ Gold Rush
gregoryf.flyboy(at)comcas Guest
Posted: Tue Feb 02, 2010 3:40 pm Post subject: Voltage drop |
First place I would look would be the large capacitor connected right next
to the regulator. Make sure it has the same capacity and/or is not open. A
bad cap might affect the regulator output.
Greg F.
rampil
Posted: Wed Feb 03, 2010 7:06 am Post subject: Re: Voltage drop |
before chucking the expensive regulator , you might check to see that
alternator is putting out the appropriate 16 or so Vac, although odds are on the regulator.
europabill(at)bellsouth.n Guest
Posted: Wed Feb 03, 2010 9:09 am Post subject: Voltage drop |
Jeff,
I would check your ground connections to the regulator, capacitor, etc.
along with associated crimp connetors.
A010
air.guerner(at)orange.fr Guest
Posted: Thu Feb 04, 2010 12:19 pm Post subject: Voltage drop |
Hi Jeff,
Have you cross-checked your indicated voltage with another voltmeter?
Remi Guerner
F-PGKL
quick place for me to look I would like to hear from you.>>>>>>>>>>>
Posted: Thu Feb 04, 2010 12:51 pm Post subject: Voltage drop |
Havent had time to do anything yet but thanks to you all I have made a list of what to check first. I will let all know of my results as soon as I get to it. Man I need to retire! NO TIME!
On Feb 4, 2010, at 2:14 PM, Remi Guerner wrote:
| Quote: | Hi Jeff,
Remi Guerner
F-PGKL
href="http://www.matronics.com/Navigator?Europa-List">http://www.matronics.com/Navigator?Europa-List
