wigwag flasher with one light
rv6n6r(at)comcast.net
PostPosted: Tue Apr 18, 2006 8:43 pm    Post subject: wigwag flasher with one light Reply with quote
I bought the Aeroelectric SSF-1 wig-wag flasher and used it happily but just
recently swapped out one of my lights for an HID so I'll only be flashing
the other (Duckworks halogen) light.
The SSF-1 is designed for 2 lights and the directions say it won't work
without a load on both sides. Any ideas about getting this thing to "wig"
without a "wag"?
Randall Henderson
RV-6
flyboy.bob(at)gmail.com
PostPosted: Tue Apr 18, 2006 9:24 pm    Post subject: wigwag flasher with one light Reply with quote
Randall,
Put a resistor in place of the bulb where the "HID" moved in (probably
near the WW circuit? 55W/14V= about 4A 4A/14V = About 3.5 Ohms . .
. the resistor will probably get a little warm? and probably 50+W
version? will probably be several inches long, or parallel two 7 ohm
30W resistors, etc.
There may be a better dummy load but the above will work.
Good Luck,
Bob in SE Iowa
without a "wag"?
Randall Henderson
RV-6
