tc1917(at)bellsouth.net Guest
Posted: Mon Feb 01, 2010 5:13 am Post subject: 912 |
Been lurking and want to say a couple of things. I had a 582 on my
slingshot and it was a real performer, to me anyway. It was LOUD. It had a
fuel consumption of around five and a half to six gals an hour + if I was
loaded and heading to Florida. I found some $$ and got hooked up with a 912
UL from Kolb. Got the works. I gotta tell you all, with this set-up, I
dont think you could beat it. I think it is the most perfect combination
you could have. I use 3 gals per hour at about 85 mph cruise. I can load
it to the hilt and still get close to the same. It has climb ability second
to none. I love my little slingshot. Only one problem, rum rum. Cant get
rid of it. So far I have done every modification known to man. Still
there. One thing left is the gear box. Not on the replacement part list
but I have the belief it has tight gears in it or is elliptical or
something. You can pull the prop around with the plugs out and still feel
it is tight in spots. Now the problem. How will I ever get the people to
warrantee the fix after almost 300 hours on it. The problem was original
but time has gone on. I am so embarrassed with this sound. I cannot get it
out even with the new helmet electronics. At this point I am willing to pay
for the gear inspection and replacement. Should not have to. Going to call
Ronny today and see what I can do. I dont want to pull the box myself.
Would rather fly to him or to Lockwood and stay until it is fixed. Anybody
have any other ideas? Not the mounts, exhaust pipes, carbs, (maybe timing),
engine not really rolling, just sounds like it is, compression equal on all
four, plugs replaced (twice). Even ready to put the new muffler on the
pipes except dont like the idea of hanging another five or eight pounds on
the backside of my CG. Someone want to come and fix this for me? I will
pay you. Anyway, I still have the most perfect flying machine. One thing
for sure, you can always tell it is me coming. Ted Cowan, Alabama,
Slingshot 912UL
lucien
Joined: 03 Jun 2007 Posts: 721 Location: santa fe, NM
Posted: Mon Feb 01, 2010 6:35 am Post subject: Re: 912 |
| tc1917(at)bellsouth.net wrote: | Been lurking and want to say a couple of things. I had a 582 on my
Slingshot 912UL |
Seems like we had a thread on this a while back which was actually my fault (was chasing a harmonic problem on my plane).
The tightness you feel when you pull the prop through with no plugs in it is the normal drag of the pistons in the engine itself. Also the oil pump adds drag once the oil pressure builds up. You'll feel all this is regular pulses in drag as you rotate it.
If it really is tight in some regular spot in the prop rotation, you got a major problem, probably would have already put you down in a field somewhere. Sounds unlikely unless you delivered a heavy prop strike or something along those lines.
As for the rum-rum, it's not a problem unless it's bad enough to buzz things in the plane. If panels, windscreens, RAIM mounts for GPS's, etc., get blurry around their edges and you have a really hard buzz in the seat from it, yeah it's something you'll want to address ASAP. But if things are staying in focus and not moving and all you have is the noise, probably not a problem.
On my plane, the problem was only fixed by going to a different type of prop with a different resonance on the blades. Completely cured the vibration. There's an audible harmonic but things sit still in the plane with no blurs or wobbles. Problem solved.
IIRC, the 80 horse has a 2.27:1 ratio unless you order it with the 2.43. Every one of these I've heard with a 3 blade prop has an almost perfect 4th harmonic. That could be what you're hearing.
Once you get into that engine things get bank-robbery expensive, so I wouldn't do that unless you really have a problem with the motor and have completely exhausted everything else....
LS
_________________ LS
Titan II SS |
Thom Riddle
Posted: Mon Feb 01, 2010 11:16 am Post subject: Re: 912 |
Ted,
As a fellow Slingshot driver, I appreciate the fine qualities of our airplanes and wish I could add something to help with your non-Caribbean Rum Rum, but can't. I was wondering if you have posted photos of your slingshot somewhere on the internet, or if not, could you post some on this list. I'd like to see yours and would guess none of the other Kolbers would object to seeing it either.
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
Thom Riddle
Posted: Mon Feb 01, 2010 11:17 am Post subject: Re: 912 |
Ted,
Buffalo, NY (9G0)
- Anonymous |
zeprep251(at)aol.com Guest
Posted: Mon Feb 01, 2010 2:09 pm Post subject: 912 |
Ted,
Four of us went together on the purchase of a dynamic prop balancer.The first unit we experimented on was Mike Bakers 912uls Savannah.I thought it was a smooth running unit until we balanced the IVO.What a difference .
G.Aman MK3C Jabiru 2200A Sensenich (balanced)
Posted: Mon Feb 01, 2010 2:32 pm Post subject: 912 |
Have you balanced a Warp Drive with HP hub yet?
Would be interested in your results, if you do.
john hauck
[quote] Four of us went together on the purchase of a dynamic prop balancer.The first unit we experimented on was Mike Bakers 912uls Savannah.I thought it was a smooth running unit until we balanced the IVO.What a difference .
_________________ John Hauck
Titus, Alabama |
Posted: Mon Feb 01, 2010 2:41 pm Post subject: 912 |
John,
Left for Fla.soon after our purchase.I'll ask
G.Aman
Posted: Mon Feb 01, 2010 3:55 pm Post subject: 912 |
Ted,
If you have not already done the dynamic balance thing,consider it.
G.Aman
Posted: Mon Feb 01, 2010 5:08 pm Post subject: 912 |
<Ted,
Thom Riddle>
I've got the "caribbean" rum rum
Some kind of Bean anyway.
[img]cid:34485858-935C-4DED-9706-7CF55C770598(at)frontiernet.net[/img]
caribbean
45.54 KB |
4508 Time(s) |
Dennis.Kirby(at)kirtland. Guest
Posted: Tue Feb 02, 2010 2:53 pm Post subject: 912 |
Ted –
Have you tried a two-bladed prop?
That may eliminate the “fourth harmonic” which Lucien spoke about.
As one who also suffered the innocuous, yet damaging, effects of harmonics from a specific engine/prop/airframe combination, I sympathize with your situation.
(My solution was: I ended up switching engines.)
Just a thought …
Dennis Kirby
New Mexico
