door handle & mechanism
roxianmike(at)msn.com
PostPosted: Sat Jan 09, 2010 9:01 pm    Post subject: door handle & mechanism Reply with quote
 I can't be the first to declare the Van's door handle and mechanism a total RPITA.......although not an engineer..........even I could design a mousetrap better than this.  After sanding the powder coat off of the shaft handle C the spring is still too small to move on the shaft and make the mechanism work.  I thought bringing in my Saturday night consulting engineer Jack (Daniels) would help but we finally gave up tonight.  Maybe a bigger hammer tomorrow will bring success. [quote][b]
jeff(at)westcottpress.com
PostPosted: Sat Jan 09, 2010 9:37 pm    Post subject: door handle & mechanism Reply with quote
Try filing out the area in the shaft that the pin travels up and down in... that's where mine bound up.
Jeff Carpenter
40304
On Jan 9, 2010, at 8:57 PM, Roxanne and Mike Lefever wrote:
I can't be the first to declare the Van's door handle and mechanism a total RPITA.......although not an engineer..........even I could design a mousetrap better than this. After sanding the powder coat off of the shaft handle, the spring is still too small to move on the shaft and make the mechanism work. I thought bringing in my Saturday night consulting engineer Jack (Daniels) would help but we finally gave up tonight. Maybe a bigger hammer tomorrow will bring success.
rvdave
PostPosted: Sat Jan 09, 2010 9:52 pm    Post subject: Re: door handle & mechanism Reply with quote
I thought maybe they gave me the wrong sized spring but I was able to unwind(?) the spring a little to fit the shaft and now works fine.
Dave Ford
Cadillac, MI
partner14
PostPosted: Sat Jan 09, 2010 9:58 pm    Post subject: door handle & mechanism Reply with quote
Spring for the cnc machined handles.... they work perfectly, are a direct Vans replacement, and they look WAY better.
Don McDonald
--- On Sat, 1/9/10, Roxanne and Mike Lefever <roxianmike(at)msn.com> wrote:
From: Roxanne and Mike Lefever <roxianmike(at)msn.com>
Subject: door handle & mechanism
Date: Saturday, January 9, 2010, 8:57 PM
get=_blank rel=nofollow>http://www.matronics.com/Navigator?RV10-List
=nofollow>http://forums.matronics.com
blank rel=nofollow>http://www.matronics.com/contribution
 Filesize:  142.83 KB
 Viewed:  5034 Time(s)
Don A. McDonald
40636
PostPosted: Sat Jan 09, 2010 10:04 pm    Post subject: door handle & mechanism Reply with quote
thanks
Subject: Re: door handle & mechanism
Date: Sat C 9 Jan 2010 21:15:39 -0800
Jeff Carpenter
40304
On Jan 9 C 2010 C at 8:57 PM C Roxanne and Mike Lefever wrote:
[quote]  I can't be the first to declare the Van's door handle and mechanism a total RPITA.......although not an engineer..........even I could design a mousetrap better than this.  After sanding the powder coat off of the shaft handle C the spring is still too small to move on the shaft and make the mechanism work.  I thought bringing in my Saturday night consulting engineer Jack (Daniels) would help but we finally gave up tonight.  Maybe a bigger hammer tomorrow will bring success.
ronics.com
kearney
PostPosted: Sun Jan 10, 2010 12:00 pm    Post subject: door handle & mechanism Reply with quote
Hi
Be careful when filing out the slot, do as little as possible. You will get a little "slop" in the handle movement as the pin can now wiggle a bit in the slot. I think you want to keep this to a minimum.
I also found that a little white grease goes a long, long way to making the mechanisms move easily and smoothly. There is a *huge* amount of internal friction in the mechanism. The grease deals with this effectively - or so I found. I put it on the tubes, gears and rails etc.
Cheers
Les
#40643
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Roxanne and Mike Lefever
Sent: January-09-10 11:01 PM
Subject: RE: door handle & mechanism
thanks
Date: Sat, 9 Jan 2010 21:15:39 -0800
Jeff Carpenter
40304
[quote] I can't be the first to declare the Van's door handle and mechanism a total RPITA.......although not an engineer..........even I could design a mousetrap better than this. After sanding the powder coat off of the shaft handle, the spring is still too small to move on the shaft and make the mechanism work. I thought bringing in my Saturday night consulting engineer Jack (Daniels) would help but we finally gave up tonight. Maybe a bigger hammer tomorrow will bring success.
ronics.com
Strasnuts
PostPosted: Thu Jan 14, 2010 7:05 pm    Post subject: door handle & mechanism Reply with quote
Hey Don,
Where did you find these CNC machined handles?
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours
kearney
PostPosted: Thu Jan 14, 2010 7:45 pm    Post subject: door handle & mechanism Reply with quote
Sean
If these are the ones you want : davidnellis691(at)comcast.net (davidnellis691(at)comcast.net)
I have a set and they are very nice. I also used Steve Deniri's billed handles on the outside for a nice flush fit.
Cheers
Les
#40643
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Seano
Sent: January-14-10 8:04 PM
Hey Don,
Strasnuts
PostPosted: Thu Jan 14, 2010 8:07 pm    Post subject: door handle & mechanism Reply with quote
Cool thanks
On Jan 14, 2010, at 20:30, "Les Kearney" <kearney(at)shaw.ca (kearney(at)shaw.ca)> wrote:
[quote] Sean
If these are the ones you want : [url=mailto:davidnellis691(at)comcast.net]davidnellis691(at)comcast.net (davidnellis691(at)comcast.net)[/url]
Cheers
Les
#40643
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Seano
To: [url=mailto:rv10-list(at)matronics.com]rv10-list(at)matronics.com (rv10-list(at)matronics.com)[/url]
Hey Don,
780 Hours
SuperSTOL 60 hours
