daveleikam(at)wi.rr.com Guest
Posted: Wed Jan 13, 2010 5:42 pm Post subject: oil adapter spacer |
For those who have installed the B&C angled oil adapter, what size spacer did you need if any?
Dave Leikam
RV-10 #40496
N89DA
Muskego, WI
partner14
Posted: Wed Jan 13, 2010 6:07 pm Post subject: oil adapter spacer |
Dave, I was a real newbie when I ran into this issue.... and I didn't know the matronics board existed... Anyway, I made my own adaptor which attatched to the engine, and a second, stock, adaptor went on next. It looked to me that the mount needed to be both spaced rearward and offset. It appears to have worked.... engine performing beautifully, with all the right pressures, for over 100 hours.
Don McDonald
--- On Wed, 1/13/10, Dave Leikam <daveleikam(at)wi.rr.com> wrote:
Subject: oil adapter spacer
To: "RV-10 matronics" <rv10-list(at)matronics.com>
Date: Wednesday, January 13, 2010, 5:42 PM
Dave Leikam
RV-10 #40496
N89DA
Muskego, WI
get=_blank rel=nofollow>http://www.matronics.com/Navigator?RV10-List
=nofollow>http://forums.matronics.com
blank rel=nofollow>http://www.matronics.com/contribution
660.61 KB |
2463 Time(s) |
163.01 KB |
2463 Time(s) |
40636 |
ricksked(at)cox.net Guest
Posted: Wed Jan 13, 2010 6:39 pm Post subject: oil adapter spacer |
Dave you will need the adapter…here is a link to B & C and I think you need the .75 or ¾”…I really can’t remember…I need to go and measure if someone else doesn’t pipe in.
http://www.bandc.biz/oil-filter-adapter.aspx
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Leikam
Sent: Wednesday, January 13, 2010 5:42 PM
To: RV-10 matronics
Dave Leikam
RV-10 #40496
N89DA
Muskego, WI
| Quote: | | http://www.matronics.com/Navigator?RV10-List | 0123456789
