Panel Photos
flyv35b(at)minetfiber.com
PostPosted: Sat Feb 20, 2010 6:15 am    Post subject: Panel Photos Reply with quote
Here are a couple of photos of the panel on my Lynx which I did about 4 years ago using Gary's eyebrow.
Cliff
The message is ready to be sent with the following file or link attachments:
Note: To protect against computer viruses, e-mail programs may prevent sending or receiving certain types of file attachments. Check your e-mail security settings to determine how attachments are handled.
 Filesize:  64.1 KB
 Viewed:  2397 Time(s)
 Filesize:  73.48 KB
Discover
PostPosted: Sat Feb 20, 2010 6:49 am    Post subject: Panel Photos Reply with quote
Real nice Cliff. I like the EI gauges. Is your altimeter crystal cracked?
PostPosted: Sat Feb 20, 2010 7:03 am    Post subject: Panel Photos Reply with quote
I think you mean the VSI? I think that is some odd light reflection. Here is another photo of it.
Cliff
 Filesize:  1.45 MB
PostPosted: Sat Feb 20, 2010 7:09 am    Post subject: Panel Photos Reply with quote
If I was doing it over again I might use the Mitchell instruments as they are much cheaper and take up a lot less panel space. I do like the accuracy of the EI instruments and having a volt and ammeter in the same instrument as well as oil pressure and temperature. The FP-5L is the primary one so that fuel pressure is shown on that instrument. Adding the EI instruments at the top of the standard panel was only possible because of Gary's eyebrow which angles up so that you can now see clear to the top of the panel (a very nice mod). A full length light strip is hidden up under the lip of the eyebrow and floods the entire panel.
Note that I have a separate analog voltmeter on the RH side which is tied in to an emergency buss.
Cliff
