eric hendriks
Posted: Fri Jan 08, 2010 8:31 am Post subject: seria nr |
Hello
I have a kitfox wit serial nr 802
For the dutch FAA there must be a non removable serial nr in the fuselage
Does anyone know if there is such a nr punched in the frame
I can do it myself but if there is already one then it ls not necessary
Thanks eric
lcfitt(at)sbcglobal.net Guest
Posted: Fri Jan 08, 2010 9:44 am Post subject: seria nr |
Eric,
I am not sure about the early Models, but in the Model IV, the serial number
is stamped on the center shoulder harness bracket.
Lowell
7suds(at)Chartermi.net Guest
Posted: Fri Jan 08, 2010 1:31 pm Post subject: seria nr |
I believe my 4 XL was stamped on the cross member below the dash
Lloyd C
Mod 5 912ul
Ivo IFA
Iron Mtn Mi.
Eric,
