Back up Fuel Pump
Goto page 1, 2  Next
captaindonhopkin(at)aol.c
PostPosted: Mon Dec 28, 2009 12:45 pm    Post subject: Back up Fuel Pump Reply with quote
Hi gang,
I believe this subject was discussed sometime ago, but I can't find the digest link for it. We'd like to add a back up electric fuel pump in my Yak 52. Does anyone has schematics, drawings, photos or any suggestions they'd like to share? Thanking you all in advance. Ciao.
Don
Captain Don Hopkin
N6868Y
myscottfree.com : Web site
harley(at)siriusconinc.co
PostPosted: Mon Dec 28, 2009 1:40 pm    Post subject: Back up Fuel Pump Reply with quote
what's wrong with the manual back-up pump?
Martin
[img]cid:28BE0150D8FE4773985CC27746CC6205(at)sci8bb5d3902fe[/img]
 Filesize:  30.47 KB
 Viewed:  21905 Time(s)
keithmckinley
PostPosted: Mon Dec 28, 2009 7:00 pm    Post subject: Re: Back up Fuel Pump Reply with quote
Hi Don,
I'm at a loss to why some people post answers like the first one you received to a perfectly legitimate question. I too, was looking to put an electric pump in my CJ. I got some great responses and the best was from Larry Pine who provided me with a fantatic schematic and cockpit view of his beautiful work. I can ask Larry if it would be OK to share. Again, it is for a CJ but it might help you out. Let me know off line.
Best,
Keith
talew(at)bellsouth.net
PostPosted: Mon Dec 28, 2009 7:55 pm    Post subject: Back up Fuel Pump Reply with quote
Kieth,
I agree with your take on that response concerning the fuel pump . When the main fuel pumps fails , the standby manual pump is on thr wrong side of the cockpit
on a CJ. This requires a lot of cross cockpit hand movement  at a critical time in the flight.
An electrical backup is a great fix for this problem.
Terry Lewis
dsavarese0812(at)bellsout
PostPosted: Mon Dec 28, 2009 8:47 pm    Post subject: Back up Fuel Pump Reply with quote
Capt. Don has a Yak 52. The primer pump on the 52 is also used to pressurize the system side, much like the big wobble pump handle on the CJ. I can guarantee you the 52 requires significantly more effort to pump enough fuel to keep the engine running if the fuel pump fails.
Dennis
bwade154(at)yahoo.com
PostPosted: Tue Dec 29, 2009 8:47 am    Post subject: Back up Fuel Pump Reply with quote
About 8 years ago there was a Yak 52 coming east from California the aircraft was new to the pilot owner and he overestimated his fuel reserve and about 5 miles from his destination airport the engine lost power he used the hand pump (primer) to make enough power to get the aircraft to the threshold the story was in the Yak club flier. So the hand pump (primer) must pull fuel from a very low point. Two questions for Dennis will an electric pump push fuel through the mechanical pump (not turning) or could you select pipe on the primer and turn it on?
Bill Wade
From: A. Dennis Savarese <dsavarese0812(at)bellsouth.net>
To: yak-list(at)matronics.com
Sent: Mon, December 28, 2009 11:38:05 PM
Subject: Re: Re: Back up Fuel Pump
Dennis
Dale
PostPosted: Tue Dec 29, 2009 9:39 am    Post subject: Re: Back up Fuel Pump Reply with quote
I sent Don the information and photo's on my 52TW he can copy.
It uses a electric fuel boost pump as intalled from Russia.
barryhancock
PostPosted: Tue Dec 29, 2009 10:00 am    Post subject: Re: Back up Fuel Pump Reply with quote
Gang,
We have developed a kit for the CJ that removes both the wobble pump and primer plunger. A stand by electric fuel pump serves as both an emergency pump and the primer. Primer is done via a solenoid on the firewall tied into a three way switch (MOM up for prime, ON down for boost). Kit includes pump, solenoid, hard lines (both to/from the pump and from the gascolator to the solenoid), fittings, and picture instructions. Please contact us off list for pricing and details.
Happy Flying,
Barry
Barry Hancock
Worldwide Warbirds, Inc.
www.worldwidewarbirds.com
yakplt(at)yahoo.com
PostPosted: Tue Dec 29, 2009 10:12 am    Post subject: Back up Fuel Pump Reply with quote
Keith, I'd personally love to see that schematic and installation pictures myself. Just FYI, my UTVA-66 (made in Yugoslavia) has many of the same parts found in the YAK. One thing that was "almost" the same was the manual priming pump. It has been replaced with a Weldon J style 8100 series electric pump http://www.weldonpumps.com/j8100.htm
In addition, an electric solenoid valve has been added so that engine priming is done simply by pushing an electric button! Pretty cool and it works perfectly.
The 8100 series has ... quote: " Low Pressure Drop Bypass Valve Permitting Passage of fuel through an Idle Pump" This feature allows it to be installed in-line with the main fuel flow going to the engine driven mechanical pump. Putting a pump in this way allows you to turn it on... then push a button to prime, or leave it running as a backup pump to the one driven by the M-14. The GSO-480 uses a pressure carb as does the M-14. Having fuel pressure present right at the carb allows for much easier starts in cold weather. Fuel pressure is adjustable at the pump.
I have not put this mod in my YAK-50, but I can tell you that this thing works FLAWLESSLY in the UTVA-66, and I use it ALL the time on the hot GS0-480 engine when it tends to vapor lock on a hot start.
A much easier installation could be done in the YAK models simply by having a manual selector valve in the cockpit to replace the current manual pump, allowing selection of fuel pressure either to "system" or to "prime", along with an electric switch to turn on the pump, I think I might even have a three position switch for the pump. "OFF" "ON" and SPRING LOADED OFF". Spring loaded off would allow you to select prime, and then just hit the switch a few times "squirting in fuel". Turning it to "ON" and selecting SYSTEM, would then allow a backup to the main engine driven pump.
I'm just thinking out-loud here. There are many ways to do it, but personally I think it's a great idea and worth doing.
Good luck,
Mark Bitterlich
--- On Mon, 12/28/09, A. Dennis Savarese <dsavarese0812(at)bellsouth.net> wrote:
Date: Monday, December 28, 2009, 11:38 PM
Dennis
yakplt(at)yahoo.com
Could you post that info to this list as well?
I think it is valuable information.
Mark Bitterlich
--- On Tue, 12/29/09, Dale <hdinamic(at)qwest.net> wrote:
Subject: Re: Back up Fuel Pump
Date: Tuesday, December 29, 2009, 12:39 PM
--> Yak-List message posted by: "Dale" <hdinamic(at)qwest.net (hdinamic(at)qwest.net)>
http://forums.matronics.com/viewtopicp; the Contribution link below to find out more ww.matronics.com/contribution" target=_blank>http://www.matronics.com/con; -Matt Dralle, Lisr?Yak-List" target=_blank>http://www.matronics.com/Navigator?Yak-List -->
radiopicture
PostPosted: Tue Dec 29, 2009 1:50 pm    Post subject: Back up Fuel Pump Reply with quote
Would like to see that, too...
http://forums.matronics.com/viewtopic.php?p 79103#279103
Dale
PostPosted: Tue Dec 29, 2009 2:35 pm    Post subject: Re: Back up Fuel Pump Reply with quote
Simple- the fuel pump ( $43.00 ) is mounted parallel to the engine driven pump. Fuel is taken from the gascolator/screen and delivered to the inlet side of the bubbler from the engine driven pump ( not on a CJ ). The Facet pump has a internal check valve keeping fuel from going back to the gascolator. Turning on the pump charges the carb for starting as well. Have fun with the plumbing. The TW uses hard lines but no reason hose can not be used. Facet # 40164 - 24V Neg. Ground, 4-C PSI Max, 30 GPH, 1/8 x 27 internal pipe ports. This install does not interfear with the normal flow of fuel. One switch one pump with 2 lines and fittings. Should cost under $150.00 for everything.
PostPosted: Tue Dec 29, 2009 3:03 pm    Post subject: Back up Fuel Pump Reply with quote
Hi Dale,
What is a bubbler ?
Terry
Dale
PostPosted: Tue Dec 29, 2009 3:18 pm    Post subject: Re: Back up Fuel Pump Reply with quote
Bubbler removes the vapor from the fuel and returns it back to the system prior to being sent to the final fuel screen and on to the caburator.
Normally only found on a Yak or a CJ if it's lucky. Located on the right side of the firewall about the size of a softball. Looks a little like Sputnik.
Yaks have the balls and CJ don't ( normally ).
yakplt(at)yahoo.com
PostPosted: Tue Dec 29, 2009 3:45 pm    Post subject: Back up Fuel Pump Reply with quote
What you suggest makes sense. The Facet pump is a VERY good pump. However I am curious.
This is a "six of one, half a dozen of another" kind of question, but which method would be better do you think?
Putting a pump in parallel as you describe, or putting a pump in series as I mentioned?
If a pump in series failed for some reason and parts clogged it up, you would of course lose engine fuel and that would be that!.
If the one way check valve in the Facet pump failed and went "bi-directional" in a parallel arrangement, the engine pump would cavitate and the same thing would happen. No engine fuel.
Which way is better?
On my UTVA it is in series. I am NOT saying "that is a better way". I am curious what others think and why.
Mark Bitterlich
Date: Tuesday, December 29, 2009, 5:35 PM
http://forums.matronics.com/viewtopic.php?p=279139#279139
http://www.matronics.com/contributionnbsp;--> http://f=======================
yakplt(at)yahoo.com
Question: What's wrong with the manual backup pump?
Answer: There isn't one.
There is a manual priming pump. This same manual pump can also be used to put some initial head pressure to the engine driven pump (system).
However, using this pump to keep the engine going if the engine driven mechanical pump fails (a geared pump) is highly unlikely. Yes, it could be used to stretch a glide, etc., etc., but you are going to be one busy bee trying to pull that thing in and out fast enough to keep the engine actually running. I think a good way to describe trying to do that would be best said as using the plunger pump to carry the aircraft to the scene of the accident.
There are indeed stories of people that have claimed to have actually pulled this off, but honestly.... I have my doubts. That plunger pump is is not a continuous pressure pump and at best you are going to get quick "shots" of power as you pump the crap out of this thing.
An electric pump would indeed meet the definition of a "backup fuel pump" while also being a very cool tool for priming.
Mark Bitterlich
--- On Mon, 12/28/09, harley(at)siriusconinc.com <harley(at)siriusconinc.com> wrote:
From: harley(at)siriusconinc.com <harley(at)siriusconinc.com>
To: yak-list(at)matronics.com, captaindonhopkin(at)aol.com
Date: Monday, December 28, 2009, 4:38 PM
Martin
PostPosted: Tue Dec 29, 2009 3:50 pm    Post subject: Back up Fuel Pump Reply with quote
Bill,
If one installs an electric primer pump on the Yak 52, it should be in the primer line which is a 6 mm line coming from the fuel junction just below the front seat to the primer pump. The procedure would be to turn the primer pump to the left (system side) then turn on the electric pump. This will pump fuel through the mechanical pump which would be more than what you could pump with the hand primer pump.
Dennis
Dale
PostPosted: Tue Dec 29, 2009 4:46 pm    Post subject: Re: Back up Fuel Pump Reply with quote
In the event of a total failure the engine driven pump has much larger lines feeding the bubbler and the would cause the Facet to act like a pressure relief valve to the extent of the leak or bypass which would need to be a total failure and them I don't see how all the fuel would bypass. The pump should not cavatate any more than a fuel pressure relief in a Duke pump or a Weldon with pressure relief. This is how Aerostar installs it in the Yak.
Dale
PostPosted: Tue Dec 29, 2009 5:03 pm    Post subject: Re: Back up Fuel Pump Reply with quote
I forgot to add that with the parallel system and the Facet you have enough room that you can put in 6 check valves downstream of the boost pump if you think the one in pump might fail for all the money you save buying the Weldon and still retain you original system without messing with the primary line. A pump in series would also be trying to push fuel through a " don't forget" gear drive pump that has failed which is why the boost pump is there to begin with.
radiopicture
PostPosted: Tue Dec 29, 2009 7:22 pm    Post subject: Back up Fuel Pump Reply with quote
I would think the mechanical fuel pump output that is plugged up
(which used to go to the oil dilute) could be used for the Facet
output. Is that true, or wouldn't that work? I assume you'd have to do
some mix and match fittings for the input side. Does anyone if
Aerostar now using American sizes, or some kind of conversion to use
the Facet pump?
Remarks?
http://forums.matronics.com/viewtopic.php?p 79161#279161
Goto page 1, 2  Next
Page 1 of 2
