A Christmas Current Regulator for All.....
Eric M. Jones
PostPosted: Thu Dec 24, 2009 1:32 pm    Post subject: A Christmas Current Regulator for All..... Reply with quote
Happy Holidays.
This is a noise-free current regulator that will power up to three LEDs in series such as the Cree 350-700 lumens stars. ~2100 (maybe) lumens!
I have made a few of these to replace noisey Buck_Pucks. I don't have any plans to sell as a product, but you can make your own or get together with friends and make a bunch (Okay, nerds have odd choices of how to have fun get-togethers).
This uses the isolated form of the 317 Regulator. If you use the standard (non-isolated) part it is more trouble.
Design notes: This is a modified surface-mount assembly used to keep everything flat against the heat sink. Make sure the 317 gets a dab of heat sink compound.
Keep the resistor up in the air. It gets very hot. I recommend flowing epoxy over the pcb and 317 leads. You can use RTV, but don't use J-B Weld (I never thought I'd have to say that...) because it is slightly electrically conductive.
Standard issues apply--keep the leads from chaffing. I used rubber grommets super-glued in the fingers of the heat sink. This heat sink is good for 1-3 LEDs at 14.5VDC, or 6 or so at 28VDC.
I'll send the ExpressPCB file as an attachment if you email me, but this is easy to carve out of plated circuit board. Only a single-sided board is required, but you'll get a double sided-board from ExpressPCB. Forty-eight circuits for $1.25 each delivered in a few days. Cool....
Aficionados will note that different versions of voltage regulators will work for improved performance in some areas or even higher power. Yes...go for it.
currentregulators.pdf
PDF file of current regulator
 Filename:  currentregulators.pdf
 Filesize:  79.81 KB
 Downloaded:  425 Time(s)
Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net
