hgmckay
Posted: Fri Jan 15, 2010 6:29 pm Post subject: Allegro 2000 Bulbs for wing tip strobes |
Attached are two photographs of the strobe bulb for the wing tips of the Allegro 2000 LSA. Does anyone know where these bulbs can be purchased. There are no markings on th bulb itself.
Hugh G. McKay
Allegro 2000
Rotax 912 UL
N661WW
| | - The Matronics Allegro-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Allegro-List |
42.21 KB |
15361 Time(s) |
86.55 KB |
15361 Time(s) |
brad(at)vision-technology Guest
Thom Riddle
Posted: Sat Jan 16, 2010 5:28 am Post subject: Re: Allegro 2000 Bulbs for wing tip strobes |
Curiosity questions.
Have you asked Doug Hempstead about these parts?
Has Sadler begun supporting parts supply for Allegros?
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
Brian Carpenter
Posted: Sat Jan 16, 2010 12:04 pm Post subject: Allegro 2000 Bulbs for wing tip strobes |
Hugh
I ordered the replacement from Doug... I could not get it to work. Then he sent me a different bulb and a different power supply..
I'll get you the information. It took a slight mod to the silver holder.. not to bad.. Works way better....I'll email it to you direct
Brian
n3081x
--- On Fri, 1/15/10, Hugh MCKAY III <hgmckay(at)bellsouth.net> wrote:
Subject: Allegro 2000 Bulbs for wing tip strobes
To: allegro-list(at)matronics.com
Date: Friday, January 15, 2010, 7:27 PM
Hugh G. McKay
Allegro 2000
Rotax 912 UL
N661WW
_________________ BRIAN N3081X |
hgmckay
Posted: Tue Jan 19, 2010 2:47 pm Post subject: Allegro 2000 Bulbs for wing tip strobes |
Thom:
I have tried to reach Doug Hemsted by email a number of times on various subjects concerning the Allegro 2000. He has never replied to me! I do not know if Fantasy Air USA, or Sadler is producing or supplying parts for the Allegro 2000, or the Allegro 2007.
Hugh McKay
Allegro 2000
Rotax 912 UL
N661WW
Sent: Sat, January 16, 2010 8:28:50 AM
Subject: Re: Allegro 2000 Bulbs for wing tip strobes
--> Allegro-List message posted by: "Thom Riddle" <riddletr(at)gmail.com (riddletr(at)gmail.com)>
Thom Riddle
Buffalo, NY
Kolb Slingshot SS-021
Jabiru 2200A #1574
Tennessee Prop 64x31
“Civilization exists by geological consent, subject to change without notice.”
- Will Durant
http://forums.matronics.com/viewtopic.php?p=281789#281789
Thom Riddle
Posted: Wed Jan 20, 2010 5:40 am Post subject: Re: Allegro 2000 Bulbs for wing tip strobes |
Hugh,
When doing business with suppliers my preference is to use email to have a precise record of the conversation but some businesses don't always respond to email. When I owned an Allegro I found both Betty and Doug as well as their young technical guy (can't remember his name) to answer or return phone calls promptly. It was not always what I wanted but I did always get an answer of some sort using the phone.
Buffalo, NY (9G0)
- Anonymous |
Posted: Thu Jan 21, 2010 7:23 am Post subject: Allegro 2000 Bulbs for wing tip strobes |
Hugh, you might want to contact David Littlejohn at Sadler Aircraft. He's one of the 3 owners and managing partner of Sadler, which is the company that established Allegro USA LLC in Oregon.
His email is davelittlejohn(at)gmail.com (davelittlejohn(at)gmail.com)
...Brad.
[quote]--
t.j.vanduin(at)gmail.com Guest
Posted: Thu Jan 21, 2010 10:37 am Post subject: Allegro 2000 Bulbs for wing tip strobes |
Hugh,
Could you please inform me about the height of the glass part and the stitch dimension of the two bare connecting wires?
One potential supplier asked me that.
Thanks for your reply,
Theo
2010/1/16 Hugh MCKAY III <hgmckay(at)bellsouth.net (hgmckay(at)bellsouth.net)>
[quote] Attached are two photographs of the strobe bulb for the wing tips of the Allegro 2000 LSA. Does anyone know where these bulbs can be purchased. There are no markings on th bulb itself.
Hugh G. McKay
Allegro 2000
Rotax 912 UL
N661WW
hgmckay
Posted: Thu Jan 21, 2010 3:10 pm Post subject: Allegro 2000 Bulbs for wing tip strobes |
Theo: The height of the glass part from the base of the strobe bulb to the tip is 45mm. The dimension between the two bare wires is 13.5mm
, and the diameter of the glass tube is 6 mm. Can you confirm to me that the navagition bulbs in your plane are of the type shown in my photograph?
Hugh
Sent: Thu, January 21, 2010 1:35:23 PM
Hugh,
Theo
| Quote: | Attached are two photographs of the strobe bulb for the wing tips of the Allegro 2000 LSA. Does anyone know where these bulbs can be purchased. There are no markings on th bulb itself.
Hugh G. McKay
Allegro 2000
Rotax 912 UL
N661WW
[/b] |
Posted: Fri Jan 22, 2010 3:34 am Post subject: Allegro 2000 Bulbs for wing tip strobes |
Hugh,
Thank you for giving me the dimensions of the strobe tube. Unfortunately I´m 500 miles away from the plane now, so I can´t check
if your navigation bulbs are the same as the ones in my Allegro. As far as I remember, mines do have a spherical glass globe.
But I like to replace my bulbs by your version with the colored sleeves, if possible. I suggest to return to this subject after I´m back in France, around mid of February.
Kind regards,
Theo
2010/1/22 Hugh MCKAY III <hgmckay(at)bellsouth.net (hgmckay(at)bellsouth.net)>
[quote] Theo: The height of the glass part from the base of the strobe bulb to the tip is 45mm. The dimension between the two bare wires is 13.5mm
Hugh
From: theo van duin <t.j.vanduin(at)gmail.com (t.j.vanduin(at)gmail.com)>
To: allegro-list(at)matronics.com (allegro-list(at)matronics.com)
Hugh,
Theo
Hugh G. McKay
Allegro 2000
Rotax 912 UL
N661WW
target="_blank">http://www.matronics.com/Navigator?Allegro-List
