lgold(at)quantum-associat Guest
Posted: Wed Dec 16, 2009 9:57 am Post subject: New Rotax 912 stuff |
In case you have not seen the notices, Rotax has extender major overhaul time for the 912 to 2000-hours. You may need to make some checks and mods to get to 2000, depending on your engine serial number. If I read this right, if your ULS engine SN is below 5646560 or your crank case SN is below 27.811 (2006?) you will need a new crank case to go 2000Hrs. This is a bummer due to the ~$4000 price tag for a crank case.
(see http://forums.matronics.com//files/tbo_extension_138.pdf).
In addition, Rotax just come out with 4 new 912 manuals. You can download them from
http://www.rotax-owner.com/manualsintro.htm.
Les
3.52 KB |
1529 Time(s) |
