dalamphere(at)comcast.net Guest
Posted: Wed Dec 16, 2009 12:21 pm Post subject: Warm-up Problem |
Here are the symptoms/conditions:
1. King KX125, Plane Power 60a alternator, Lycoming O-320-D2A, PS
Engineering 1000II intercom, Lightspeed 20XLc headsets.
2. After engine startup initially while the battery is being re-charged, if
I press the PTT button to transmit to unicom, I'll hear a very loud
hi-pitched whistle in my headset (side-tone)- my guess is it's around 8Khz.
It doesn't appear that transmitting gets through.
3. The radio recieves very clearly during this period - say listening to
AWOS for example.
4. With the intercom off, it does the same thing.
5. After the battery is recharged, and from then on in the flight (including
re-starts after re-fuel) the radio transmits and recieves clearly.
6. There is a 2.2uF at the positive output lead of the alternator to ground.
There is a noise filter between the main bus and avionics buss.
7. A single point multi-tab ground is used.
Any ideas what to look at next??
Dave
deene(at)austin.rr.com Guest
Posted: Thu Dec 17, 2009 7:56 am Post subject: Warm-up Problem |
You should check your alternator to see if the diode bridge is OK. If a diode fails, then the output from the alt will be very noisy and especially at higher output levels…
Deene Ogden
RV8
CFII, MEI, CFIG
