				 Posted: Sun Dec 13, 2009 10:48 am    Post subject: Center-tapped batteries . . . |
				At 12:06 PM 12/13/2009, you wrote:
  	  | Quote: | 	 		  I'm planning a center-tap system to supply intermittent 12V loads
 such as a trim motor and hydraulic pump for raising my gear on my
 Velocity.  Due to the high load imposed by the hydraulic pump, using
 a voltage converter was prohibitively expensive (I looked at
 swapping out the hydraulic pump for a 24V model, but the control
 electronics are all set up for 12V as well).
    Rethink this decision. What's in the control electronics?
    If it's nothing more than relays and contactors, those are
    easy to change too.
  	  | Quote: | 	 		     My understanding is that by using a reasonably inexpensive
  battery equalizer, the negative effects of center-tapping can be
  mitigated.  Because the hydraulic pump only operates twice per
  flight, I can get away with a reasonably low amperage equalizer (I
  think I got 2 or 5 amp capacity).  Any thoughts on these equalizers out there?
    If your equalizer is a 5A device, then it cannot
    "equalize" effects on a series pair of batteries
    wherein the bottom battery is sourcing 40+ amps
    of pump loads simultaneously with the top battery
    getting a 40+ amp overcharge event.
    Running your 100 mA trim actuators from a tapped
    battery is no big deal. But much more than that
    directly affects battery service life.
    If you must center tap two batteries as proposed,
    I swap upper an lower batteries every dozen flights
    or so. I'd also cap and load-check the batteries
    more aggressively.
                    (o o)
     ===========o00o=(_)=o00o=========
     < Go ahead, make my day . . .   >
     < show me where I'm wrong.      >
