gcomfo(at)tc3net.com Guest
Posted: Mon Nov 23, 2009 5:22 am Post subject: isispower |
Posted: Mon Nov 23, 2009 9:06 am Post subject: isispower |
At 07:19 AM 11/23/2009, you wrote:
Bob: Check out isispower. I would appreciate your comments.
Gordon Comfort
Hi Gordon! Good to hear from you. I've had several folks
send me the link on this line of product. Thanks to all
for the heads-up.
Let's consider the words and images used to induce
customers to purchase this product . . .
http://www.isispower.com/V8_interview.php
There's also a library of installation and
user's manuals at:
http://www.isispower.com/isis-installation.html
I didn't go through these in detail but at no
time did I see any sort of block diagram or
all-up wiring diagram that describes an exemplar
installation. But questions to be asked and
answered:
(a) does the proposed system reduce numbers of
switches or controls on panel along with wiring
and real estate allotted to those components?
(b) how many devices in your proposed airplane
project require you to switch a current level
that places the switch at risk for extra-ordinary
rates of failure. Careful here . . . don't mix
service life (expected wear out) with reliability
(failure due to poor design or choice of component).
(c) how many devices or systems in the airplane
cannot be handled by this product? This includes
things like legacy magnetos, audio switches, etc.
(d) how does inclusion of this product in your
airplane change your failure modes effects analysis
for the purpose of crafting Plan-A/Plan-B responses
to failure of any one system?
(e) how does inclusion of this product affect
probability of single points of failure for
multiple systems?
(f) does your comfortable incorporation of this
or any similar system depend on some notion of
super-reliability or exemplar service life. I.e,
"THIS gizmo is NEVER going to malfunction".
(g) some lengths of wire between control switches and
controlled devices are replaced by data bus
conductors between "smart modules". What is the
weight savings for these conductors as compared
to the weight of the proposed "smart modules"?
(h) when and if problems do happen, what is the
likelihood that YOU as a system integrator will
be tooled and skilled in fixing the problem . . .
or will you be dependent upon outside support
or canned diagnostics?
(i) how does incorporation of this product make
your installation task any simpler than running
a conductor path from fuse to switch to accessory?
If your design goals include buffering stresses
on the switch by inclusion of a power relay, how
much $time$ is expended in the installation of
the relay, one extra wire and allocation of one
extra fuse to the task?
(j) you still have to run SOME gage and length of
wire from each control device to a smart module
at the head-end. You still have to run the SAME
gage of wire to each accessory from the smart
module at the tail-end. If you have only one tail-end
smart module where actual power handling takes
place, is this not about the same situation as
the fabrication of a breaker panel or array of
fuse blocks?
(k) think hard about this "weight reduction"
thing. If you're using fuse blocks and the SAME
or perhaps slightly smaller switches. What is
the likelihood that the combination of smart
modules comes out lighter than the sum total
of wire weight eliminated?
(l) finally, assuming consideration of all the
above produces conclusions consistent with your
design goals. Suppose you spend under $100
for all switches, relays, wire, and fuse
blocks to handle the tasks we've accepted
and lived with for nearly 100 years of operating
airplanes. What is the return on investment
for delta-dollars need to acquire this system?
Would the difference buy you a nice hand-held
GPS or radio for the flight bag?
It would be best if you did this exercise for yourselves
with input from your brothers here on the List. It's
best that the make/buy decision is made from a position
of understanding and meeting personal design goals than
to rely on anybody's advice.
marcausman
Posted: Wed Dec 16, 2009 3:33 pm Post subject: Re: isispower |
Well, the turn signals, horn, and high beams are great new features for airplanes. Be the first on your block...
Seriously though, this product is designed for automobiles. Vertical Power is designed for aircraft and therefore it's working in its intended environment.
_________________ Marc Ausman
http://www.verticalpower.com "Move up to a modern electrical system"
RV-7 IO-390 Flying |
