Posted: Thu Dec 10, 2009 4:49 pm Post subject: G3i Ignition |
Has anybody installed (or have experience with) the G3i electronic ignition system?
Jesse Saint
Saint Aviation, Inc.
Cell: 352-427-0285
Fax: 815-377-3694
jcumins(at)jcis.net Guest
Posted: Thu Dec 10, 2009 5:45 pm Post subject: G3i Ignition |
Jesse
I am going to go with this ignition system it totally make since to me being a old a&p having mags as a backup if the electronics goes out is the only way to go.
I talked to the Manager at Eagle engines they have installed it a few times and has one installed on there test stand they run all engines they work on, it looks like a great product.
I have in the past over 30 yrs ago used the MFD products on my car and they were flawless. So I am sure this product runs in line with that.
John G. Cumins
President
JC'S Interactive Systems
2499 B1 Martin Rd
Fairfield Ca 94533
707-425-7100
707-425-7576 Fax
Your Total Technology Solution Provider
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse Saint
Sent: Thursday, December 10, 2009 4:48 PM
Subject: G3i Ignition
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
012345678901234567890123456789
Kelly McMullen
Posted: Thu Dec 10, 2009 6:54 pm Post subject: G3i Ignition |
While the concept looks good in some ways, what I don't understand is
what you actually gain over a well maintained magneto. The timing
doesn't change, still fixed. So you get a multiple spark..maybe that
helps if you have an oil burner, but seems like a lot of money to gain
very little. Maybe I am missing something, maybe I misread.
On Thu, Dec 10, 2009 at 6:42 PM, John Cumins <jcumins(at)jcis.net> wrote:
| Quote: | Jesse
way to go.
A&P/IA, EAA Tech Counselor
KCHD |
Posted: Thu Dec 10, 2009 7:34 pm Post subject: G3i Ignition |
Larry vetterman used/uses it:
Now after flying it almost 100 hours, here are the reasons that I really like the G3. #1. Easy to install, even I could follow the wiring diagrams. 2. the system uses the existing mags and if there is an electrical failure, the mags operate normally. 3. the engine starts very well both hot and cold. 4. I can now run lean of peak if desired whereas before my M1B, with standard mags balked at anything beyond peak EGT. 5. I see a lower ghp with the G3 vs standard mags. 6. The M1B engine is extremely smooth with the G3. 7. I used the expensive Champion fine wire spark plugs(I had a set on the shelf) gapped to .021 however I understand that an inexpensive automotive plug can also be used
check out his site for the full report- under the prop comparison.
Pascal
Sent: Thursday, December 10, 2009 4:47 PM
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
href='3D"http://www.aeroelectric.com"'>www.aeroelectric.com
href='3D"http://www.buildersbooks.com"'>www.buildersbooks.com
href='3D"http://www.homebuilthelp.com"'>www.homebuilthelp.com
href='3D"http://www.matronics.com/contribution"'>http://www.matronics.com/contribution
href='3D"http://www.matronics.com/Navigator?RV10-List"'>http://www.matronics.com/Navigator?RV10-List
href='3D"http://forums.matronics.com"'>http://forums.matronics.com
n277dl
Posted: Fri Dec 11, 2009 10:45 am Post subject: G3i Ignition |
Kelly
Yes the electronic controller will change the timing totally. When the
electronic module is powered up it takes over for the mages but if it dies
the mages will kick in. It is totally automated when turned on.
John G. Cumins
Strasnuts
Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
Posted: Fri Dec 11, 2009 2:24 pm Post subject: G3i Ignition |
what are mages?
_________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
Lew Gallagher
Posted: Fri Dec 11, 2009 2:55 pm Post subject: G3i Ignition |
mags ... magneto's ?
_________________ non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed ! |
Posted: Fri Dec 11, 2009 3:36 pm Post subject: G3i Ignition |
John G. Cumins
President
2499 B1 Martin Rd
Fairfield Ca 94533
707-425-7100
707-425-7576 Fax
Boy don't have fat fingers on this form hehe. The vultures will eat ya a
live.
John
40864 EMP about to start priming
Strasnuts
Posted: Fri Dec 11, 2009 3:57 pm Post subject: Re: G3i Ignition |
My spelling always gets made fun of. I'm passing it along...It's a vicious cycle. I was really careful writing this one.
Does this system use MSD?
I have used MSD on high performance boats and have grown not to trust them. They were eating away at the cap and rotors and had intermittent problems which were hard to troubleshoot. Plus I got the bejesus shocked out of me. It felt like, i assume, a taser.
bejesus is a word.
1. Bejesus
A word commonly used to express great surprise or fear.
You scared the BEJESUS out of me!!!
780 Hours
Kelly McMullen
Posted: Fri Dec 11, 2009 4:35 pm Post subject: G3i Ignition |
John,
Actually, having read through the web site again, the system does NOT
change magneto timing. It uses one of the mag points to trigger, and
provides a multiple spark for 20 degrees after the trigger. In other
words, if your engine is timed to 25 degrees, it will fire at 25
degrees all the time, except during starting. While this may give you
smoother running and a tiny bit better combustion, it does NOTHING for
advancing the timing event when at less than full power, such as in
cruise. So it will do almost nothing for fuel efficiency, nor will it
provide any additional power.
Systems like the Lightspeed Plasma advance the timing event 10-15
degrees when the engine is producing something less than full power to
gain efficiency when less detonation margin is needed.
They do offer a manual advance for the MSD, but this would be
hazardous to your engine where you have no immediate feedback if
approaching ping or knock.
Kelly
40866
QB Wings
On Fri, Dec 11, 2009 at 11:35 AM, John Cumins <jcumins(at)jcis.net> wrote:
Kelly
John G. Cumins
KCHD |
Posted: Fri Dec 11, 2009 5:16 pm Post subject: G3i Ignition |
Kelly
The points are yes set to 25 degrees btdc and yes it does use the points to
trigger timing to the electronic box, but the box controls the actual firing
of the coil and also does it in numerous spark cycles, I was told between 2
- 3 spark cycles depending on rpm. So the Electronic control does control
the actual timing of the spark to the coils rotor, spark then goes to
distributor block then to the spark plug lead then to the plug itself.
The only current that flows thru the points when the Electronic control is
on is the point trigger of the engine at 25 degrees btdc that's all and so
the point will not arc or wear out.
I have heard great things and I like how this works a lot. I think it is a
much safer system then some of the other systems out there.
JUST my 2 cents worth.
John
40864 Emp
Kelly McMullen
Posted: Fri Dec 11, 2009 8:14 pm Post subject: G3i Ignition |
My point was that the system does not advance timing, so you still
have fixed timing, although there are multiple spark events from 25
degrees to 5 degrees BTDC. The only way to gain power or economy is to
advance the timing once power has decreased from full takeoff power.
On Fri, Dec 11, 2009 at 6:14 PM, John Cumins <jcumins(at)jcis.net> wrote:
Kelly
John
40864 Emp
KCHD |
Posted: Fri Dec 11, 2009 8:29 pm Post subject: G3i Ignition |
Kelly that is not correct. When the electronic unit is powered it will
control the timing of the spark not the mags. The mages only control the
timing of the spark when the electronic unit is powered off or failed. I
would recommend that you call the number on there web site he might be able
to explain it better to you than I can.
John G. Cumins
President
2499 B1 Martin Rd
Fairfield Ca 94533
707-425-7100
707-425-7576 Fax
Kellym
Posted: Fri Dec 11, 2009 8:55 pm Post subject: G3i Ignition |
Re-read their own description. The unit still uses one of the two mags
to provide the timing of the initial spark event, and all other sparks
are AFTER the initial spark. I read through the entire install manual
and all descriptions. There is NO indication that the MSD unit advances
the spark at all. The opening of the points provides the timing. There
is minimal current as long as the MSD is functional, but it still is the
points providing the timing.k The only difference is you get a multiple
spark, kind of like the difference between a single event strobe and the
Whelen Comet flash. The spark might be somewhat higher voltage, and the
system assures that both left and right plugs are fired simultaneously
even if the mag timing is different by a degree or two from left to
right, because the system only uses one mag to trigger.
John G. Cumins
President
2499 B1 Martin Rd
Fairfield Ca 94533
707-425-7100
707-425-7576 Fax
KCHD |
daveleikam(at)wi.rr.com Guest
Posted: Fri Dec 11, 2009 9:16 pm Post subject: G3i Ignition |
The way Thomas described it to me at OSH this year, as the fuel air mixture
swirls in the cylinder, the 20 degrees of spark produced by the MSD (which
always fires at 25 degrees BTDC using magneto timing, the control box does
not adjust timing) lights the mixture at different points as it swirls by.
Light a pile of hay with a flare in one spot, or light the pile in 10 spots
around the base. Which way will it fully burn faster? Think about why your
airplane engine runs better on two plugs than on one during your mag check.
This achieves similar results to advancing timing, but simpler. I am no
expert here, but it makes sense to me. Also, you can read more on the
science of advanced ignition timing in aircraft and how it relates to the
G3i concept here: http://cafefoundation.org/v2/research_reports.php
Read "Ignition dynamics I,II & III" and then this system makes even better
sense.
I looked hard at several ignition systems including Lightspeed, Electroair
and LASAR among others. I also spoke with Larry Vetterman and a friend of
Stein's who built and raced cars with MSD and installed G3i in his RV7.
They both are happy with the reliability, increased engine performance and
efficiency the G3i system provides. The system is also less than 1/2 the
price of a dual lightspeed or LASAR system, and provides full redundancy
using the mags should the system lose power. No second battery needed. I
purchased the series-2 G3i system. I hope to have it running next summer.
I recommend calling Thomas at G3i. He is a great guy to deal with and will
answer all your questions. Again I am no expert, but after my due
diligence, this system makes the most sense to me.
Dave Leikam
RV-10 #40496
N89DA
Muskego, WI
Kelly
Give the guy a call I talked to him at length and he will explain it. He
says that the total advance runs between 31- 32 degrees at full power. Just
give him a call you will be amazed.
Have a great weekend and Christmas.
John G. Cumins
President
2499 B1 Martin Rd
Fairfield Ca 94533
707-425-7100
707-425-7576 Fax
Kelly McMullen
Posted: Fri Dec 11, 2009 9:44 pm Post subject: G3i Ignition |
I don't need to call someone to find out something that is
electrically and physically impossible. If the first spark occurs at
25 degrees, no additional sparks are going to advance timing.
Multiple sparks do nothing for you unless the first spark doesn't
ignite the mixture. You still have two plugs. You would need more
plugs to ignite more of the mixture simultaneously. The CAFE reports
and Ford testing also show this. Better atomization and better mixture
distribution do far more for you than multiple sparks at lean
mixtures. I had an MSD unit on a car in the 70s, until it failed stone
cold dead. Not real interested in experiencing that in an aircraft. In
fact the CAFE reports demonstrated that Bendix 1200 mags were as good
or better than dual electronic ignition.
But experimental lets us all make our own choices. Be careful to
separate marketing hype from real data and facts.
On Fri, Dec 11, 2009 at 10:16 PM, John Cumins <jcumins(at)jcis.net> wrote:
Kelly
John G. Cumins
President
2499 B1 Martin Rd
Fairfield Ca 94533
707-425-7100
707-425-7576 Fax
KCHD |
Bob Turner
Posted: Sat Dec 12, 2009 12:48 pm Post subject: Re: G3i Ignition |
Kelly,
I have no idea how this system works but to say it's physically impossible is not correct. Here is how it might work:
The RPM's of an engine change slowly, compared to the time between cylinder firings. The black box knows the rpms, and thus the time between plug firings. From the time the points close, it can time the plug to next fire not 720 degrees, but say 710 degrees (10 degrees of advance) later. In other words, the points may control not the current firing, but the one after that, with a timer (sync'd to the rpm) controlling the actual time.
As I said, I don't know if the system does this. But it might. It certainly wouldn't be hard to implement. The only real limitation is that the distributor contacts need to be in contact at that time.
_________________ Bob Turner
RV-10 QB |
