cjhukill(at)cox.net Guest
Posted: Thu Dec 10, 2009 4:33 am Post subject: source for relay |
I'm back on the list after a couple of years building hiatus, and now am wiring my RV10. I need a source for a high quality, low holding current, 20 amp or more rated, continuous duty relay. I need one for the avionics master, and one for the alternate ebus source. I've checked the archives, and couldn't find anything. Does anyone have a source for these?
Chris Hukill
Posted: Thu Dec 10, 2009 8:01 am Post subject: source for relay |
At 06:12 AM 12/10/2009, you wrote:
| Quote: | I'm back on the list after a couple of years building hiatus, and now am wiring my RV10. I need a source for a high quality, low holding current, 20 amp or more rated, continuous duty relay. I need one for the avionics master, and one for the alternate ebus source. I've checked the archives, and couldn't find anything. Does anyone have a source for these?
Chris Hukill
Not sure what your criteria is for "low holding current".
The physics of relay construction are rather limiting when
trading off pull in voltage vs. holding current vs. meeting
specs over a wide temperature range.
For years we've recommended plastic, automotive relays
having fast-on tabs that are not unlike this . . .
http://aeroelectric.com/Pictures/Relays/Plastic_Relay_2.jpg
http://aeroelectric.com/Pictures/Relays/s704-1l.jpg
These are inexpensive and available from dozens of
suppliers.
However, given that electro-mechanical relays are the
LEAST reliable of all your power control devices,
they should be used in situations where loss of function
is either no big deal -OR- backed up with a Plan-B.
Before folks run out and start ripping relays out
of their airplanes, understand that the statement above
is comparative. Certainly our cars are fitted with
buckets full of relays. Nonetheless, most of us are
unaware of their presence because we're very seldom
faced with a need to replace one. But those are CARS
and not AIRPLANES. The rule of thumb for factoring
a relay into an airborne system design calls for due
consideration and mitigation of failure mode effects.
Bob . . . [quote][b]
